Targa_PB_78_SC
mike sampsel's Avatar
Dash pad stud install question
On the studs in the dash pad (square inserts with studs near gauges) how were they held to the dash?
I removed mine when I sent it to be recovered. Now I don’t see any glue residue. Suspect I might need to slowly bend out the four teeth so they pull the dash down? Contact cement likely okay too?
Pic of the two studs, teeth are underneath
Old 11-15-2019, 07:05 AM
I'm good with tools.
AG81's Avatar
Contact cement could work if it is industrial strength like 3M Scotch-Weld 1357 Neoprene High Performance Contact Adhesive.
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 11-15-2019, 10:36 AM
Targa_PB_78_SC
So the studs are in fairly tight to help pull the dash down a bit over the gauges, right?
Old 11-16-2019, 04:18 AM
dash
Since there can be a bit of stress on these as the dash is tightened down, I fastened mine with JB Weld. Worked great.
Old 11-16-2019, 07:52 AM
Targa_PB_78_SC
Followed your method, worked well
Old 11-18-2019, 07:11 PM
