-   -   Dash pad stud install question (http://forums.pelicanparts.com/porsche-911-technical-forum/1045178-dash-pad-stud-install-question.html)
mike sampsel 11-15-2019 07:05 AM
On the studs in the dash pad (square inserts with studs near gauges) how were they held to the dash?
I removed mine when I sent it to be recovered. Now I don’t see any glue residue. Suspect I might need to slowly bend out the four teeth so they pull the dash down? Contact cement likely okay too?
Pic of the two studs, teeth are underneath
http://forums.pelicanparts.com/uploa...1573830116.jpg
AG81 11-15-2019 10:36 AM
Contact cement could work if it is industrial strength like 3M Scotch-Weld 1357 Neoprene High Performance Contact Adhesive.
mike sampsel 11-16-2019 04:18 AM
So the studs are in fairly tight to help pull the dash down a bit over the gauges, right?
dhanl82 11-16-2019 07:52 AM
dash
Since there can be a bit of stress on these as the dash is tightened down, I fastened mine with JB Weld. Worked great.
mike sampsel 11-18-2019 07:11 PM
Followed your method, worked well
