kstylianos's Avatar
Send a message via Yahoo to kstylianos
Oil Sender Hardware...
I took the 8mm nuts off to replace the oil sender gasket. Behind the nuts are very soft washers that look to deform and seal the bolt holes. These washers obviously need replacing. Thoughts on where to find or what they are? These are not your ordinary backing washers. Not listed on the Pelican site, although I'm sure Pelican can source and ship but don't want to order $2.50 worth of parts and ship across the country.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 04-01-2003, 11:05 AM
Irrationally exuberant
ChrisBennet's Avatar
I'm not sure what you mean by the "oil sender gasket". Depending on the application, you may be able to reuse the aluminum crush washers. Are you talking about the chain box nuts (6mm, 10mm wrench), the breather gasket (on the very top of the motor) or something else?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-01-2003, 11:21 AM
kstylianos's Avatar
Chris,
I'm replacing the gasket for the oil sending unit on the oil tank under the RR fender. The old washers were pretty mangled up and can't be reused, so I need to find replacements.
Charlie Stylianos
1982 SC Targa
Old 04-01-2003, 11:25 AM
Early_S_Man's Avatar
Porsche Crest
I assume you are talking about the oil level sender cork gasket ... and soft copper M5 sealing rings ...
Try Pelican or Stoddard's
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-01-2003, 11:26 AM
kstylianos's Avatar
Warren,
Thats correct. Thank you. Hopefully the local HW store carrys them.
Charlie Stylianos
1982 SC Targa
Old 04-01-2003, 11:28 AM
You will need to be more specific as to what you mean by "oil sender gasket". Do you mean oil pressure sender crush washers, oil temp sender crush washer, oil level sender gasket or what.
To make things easier for you in the future try to get a "Parts and Technical Reference Catalog" PNA 000-147 which can be a great resource for issues like this. They run between $9 and $15 usually.
Bill W.
edit: that shows how slow I type, you already posted an update and got an answer before I typed my reply.
Bill W.
'97 Arena Red / Gray 993 Cab
'93 968 Coupe 6 Spd
'88 911 Cab Red/Blk (sold)
Old 04-01-2003, 11:34 AM
Cool
I just did a new oil level sender.. the optional rubber gasket is
# 477-919-133 from Stoddard.. lists for $5.56..... I paid $4.91
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-01-2003, 12:15 PM
kstylianos's Avatar
Thanks Ron,
I already have the cork gasket in hand and when I went to replace I found the crush washers held me back.
BTW: You use the M5 crush washers?
Charlie Stylianos
1982 SC Targa
Old 04-01-2003, 01:07 PM
Cool
I used the old washers.. but I put a little RTV on the threads before the washers.. then thin coated the wire connections, after cleaning, w/some conductivity grease/whatever, then a big glob of the RTV over the connected wire to protect it.. then I tightened down the nuts in a criss cross, in a couple of steps, to avoid warping the rubber gasket.. the cork may eventually leak. maybe it's overkill.. but I want to forget about the sender for another 100k miles........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-01-2003, 01:28 PM
kstylianos's Avatar
Thanks Ron.....
Charlie Stylianos
1982 SC Targa
Old 04-01-2003, 03:35 PM
