-   -   How to secure reverse switch wire harness? (http://forums.pelicanparts.com/porsche-911-technical-forum/1045428-how-secure-reverse-switch-wire-harness.html)
Solamar 11-18-2019 12:13 PM
I'm sure I could McGiver some adelle clamps and zip ties, but is there a correct way to secure the reverse light harness to the transmission? The harness has a rigid plastic tube over part of it.
http://forums.pelicanparts.com/uploa...1574107957.jpg
Marc Bixen 11-18-2019 12:41 PM
Yes, You're missing bracket # 915 301 369 00 and reusable strap #999 513 007 40. They go where your harness passes the nose cover, then, 2 nylon ties around the starter, slide the protective tube up to there.
Solamar 11-18-2019 01:36 PM
Perfect, thank you!
911tracker85 11-19-2019 06:11 AM
Marc,
pic?
Solamar 11-19-2019 08:39 AM
Safe to assume this little tab, riveted to the side of the case, is to support the speed sensor wire (speed sensor removed in this photo)?
http://forums.pelicanparts.com/uploa...1574181503.jpg
proporsche 11-19-2019 09:07 AM
sola..yes that is it...
here is a pic of the bracket
http://img.pccreation.net/photos/201911192344094315.JPG
http://img.pccreation.net/photos/201911191803209149.JPG
tie wrap
http://img.pccreation.net/photos/201911191808309172.JPG
Marc Bixen 11-19-2019 10:16 AM
Thanks for the pics guys, I didn't have one readily available.
proporsche 11-19-2019 11:30 AM
No problem Marc it took me while;-) unfortunately the tie wrap seems to be NLA..
Ivan
Marc Bixen 11-19-2019 01:22 PM
If you can't fid the 999 513 007 40, there's a longer one, 999 513 023 40.
ErrorMargin 10-06-2024 02:06 PM
...then, 2 nylon ties around the starter, slide the protective tube up to there.
Does anyone have a picture of where the two nylon ties go around the starter to hold the reverse switch wire harness?
