-   -   What Do I Need For A Suspension Refresh? (http://forums.pelicanparts.com/porsche-911-technical-forum/1045502-what-do-i-need-suspension-refresh.html)
Paulporsche 11-19-2019 07:55 AM
Ol Yeller has 197,000 miles on it so I think it's well past time I did some suspension freshening. I've already redone the front rotors and pads, all 4 wheel bearings, and the turbo tie rods.
I want to replace, or have revalved, the Bilstein HD shocks, and replace the sway bar bushings and drop links or bushings, along with the spring plates and/or bushings. I'll probably replace shock mount bushings too. Afterwards I'll have an alignment done.
I don't track the car anymore, and at my advanced age (71) I'm looking for a well handling but comfortable ride for myself and my long suffering wife.
Aside from what I've listed above, what else should I get from our host, and what potential pitfalls should I look out for, or special tools would I need to do this work?
And finally, can I do all this work in my garage with a jack and stands but no lift?
Thanks.
jpnovak 11-19-2019 08:02 AM
Here is my typical list for a refresh. Some parts may be deleted depending on the previous replacement. There are options for each item.
front shocks (dampers)
Front a-arm bushings
tie-rods (or tie-rod ends)
ball joints
Steering rack rebuild/regrease
front sway bar bushings (front a-arm and rear support)
Front strut bearing support (top of strut)
rear sway bar bushings (drop link and body collar)
spring plate bushings
rear shocks (dampers)
rear trailing arm bushings
I am a huge fan of any of the bearing type bushings (not rubber) I don't think they transmit much NVH into the chassis but have fantastic reduction in rotational friction. This means a planted, compliant ride especially on bad roads.
Make sure to add a corner balance to your alignment process. This makes a difference especially after it has all come apart and been assembled.
RWebb 11-19-2019 09:53 AM
well handling but comfortable ===> digressive valving on the shocks
for best comfort, reverse all the hotrod suspension mods. you did years ago
Ayles 11-19-2019 10:52 AM
You can definitely do this on jack stands. I did, but I'm also not 71 :) Be ready for trouble with some of the disassembly and be prepared to spend a fair amount of time on the ground fighting some it. That being said my Father in Law helped with a good a portion of it and he was at least 71 at the time. Not a bad set of jobs to do but having a helper will make it much more enjoyable.
mar2mar 11-19-2019 08:45 PM
If you have a Bilstein struts, you should probably change the upper seal and the sliding bearing inside the struts too.
http://forums.pelicanparts.com/uploa...1574227543.jpg
http://forums.pelicanparts.com/uploa...1574228489.jpg
Paulporsche 11-20-2019 11:53 AM
Thanks everyone.
Mar2mar,
Our host's chat function isn't working right now. Are those 2 parts readily available?
mar2mar 11-20-2019 11:01 PM
I searched around quite a bit for these parts, hoping to rebuild it myself , but I didn’t find anybody that sells them. Finally I called Bilstein, they have the parts , but they will not sell it individually. You have to send the struts to them and they will install it. That’s what I did. Before tax and shipping they charge a total of $230 for both struts. The turn around time was about 2 weeks. I’m very happy with their service and the peace of mind knowing it was professional done by Bilstein is well worth it.
Paulporsche 11-21-2019 07:23 AM
I think I'll go that route, Mar. Thanks!
jpnovak 11-21-2019 07:30 AM
Craig Garr (G2 RAcing) (Cgarr on Pelican) will rebush your Bilstein struts. His turnaround time is faster than Bilstein and at a very reasonable price. It is worth contacting him.
Paulporsche 11-21-2019 12:02 PM
I'll check him out.
Thanks Jamie.
911SauCy 11-21-2019 03:23 PM
Check book, thick one :)
