Loooking for original or substitution dowel pin for 915
Hey folks.
I have a 915 that I am missing the "dowel" or Cylinder pin 5x32. I am not sure if it is special in any way or I can simply use a similar pin ordered from mcmasterCarr. This part is NLA from porsche. See #15 below. Thanks.
1979 930 |
Any properly sized pin should do. It just holds that arm's position in the groove on the vertical shaft. Nice that the parts catalog gives dimensions.
i would suggest, do not bother to use it at all,later models do not have it.It does not do anything ...It is just a trouble later when you like to remove the arm..everything works fine without it;-)
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
+1 on proporsche.
Bruce |
This.
