Need opinion re: used modular Fuchs wheels nightmare
Need some opinion/advice. I bought a set of modular Fuchs wheels off a reputable guy on Pelican. He said they were straight and I believed him. After paying for shipping, taking possession and paying to have them refinished in a custom powdercoat I discovered the wheels are all bent, some beyond repair. Now I’m $3K into them and the wheel refinisher says it will cost me another $2K for new inner and outer hoops to rebuild them properly.
Question is: should I bite the bullet and get them rebuilt right or cut my losses and return them to the seller, who says he will only refund me my original purchase price and I must cover return shipping back to him. He will end up with the same wheels looking better than ever and I will be out about $1K with nothing to show. I’m really torn... Before https://uploads.tapatalk-cdn.com/201...c21f593713.jpg After https://uploads.tapatalk-cdn.com/201...7d0a7a67ff.jpg Sent from my iPad using Tapatalk |
Take the hit and move on. Sorry for your loss but you're knee deep in a sH#$% storm.
Make Extra sure the refund is gonna happen. Burned once, twice shy. |
I'd get another opinion on whether they are bent and how much they would be to repair. Go to someone that specializes in wheel repair.
NYNick is right in that you need to minimize the loss and move on - just make sure that's the right move. |
Man, that’s horrible. I would get a second opinion. I have heard of having wheels repaired “good as new”. What brand of inners/outers are they? Surely some of the pieces are salvageable? Would the seller be willing to discount your purchase? Obviously, the centers are still worth a decent amount of $.
Sorry to hear about the mess. Agree with the previous comments.
The last thing you want is to be burned again by the "reputable guy". |
I went to 2 wheel shops. No.1 wouldn’t go near it, no.2 said 2 are salvageable. Of course it’s one front and one rear which means I can’t make it cosmetically match (would have been easier to have two identical fronts or rears). Sent from my iPad using Tapatalk |
See if 20 bolt BBS halves will fit. Good used ones can be had for $100-150 each.
Shame on the guy who refinished the wheels for not checking them for straightness before refinishing them. I'd think that's wheels 101. |
I find that you called the seller 'reputable' a bit ironic. it would be nice to call him out, but the only way to ethically do so would be for members to PM you for their name here. |
I’ve bought and sold a lot of wheels, and get that it can be hard to tell some times. As a seller though, you should be responsible enough to know especially if you are going call that out in your listing. As others have said, the refinisher should have checked too. If it’s any consolation, they look great. |
Every reputable wheel refinishing place I've heard of spins each wheel for trueness before starting to refinish them....why didn't yours?
I`d probably return the wheels name the guy and buy a set from augmentwheels.com (and they are Canadian)
Who is the seller. This is not on for a site that revolves around trust and friendship.
If the center is bent, machining isn't going to sort it. It will need to be replaced. If it was machined poorly the first time and has too much runout, then machining will fix. If there is powdercoat where there shouldn't be, the lips won't lay flat to the flange and that will show as out of true or out of round. Similarly if there is uneven powder on the hub surface. Uneven sealant (silicone/rtv) that is laid in between the sandwiched wheel shells/center will also present as out of true/round. Did the wheels come with tons of wheel weights on them? A bent wheel will shake a car to bits. 2 of them would render it nearly undrivable. With the limited info we have here, I'm far more suspicious of your refinisher than than the seller at this time. |
I have abandoned and repaired really expensive rims over the years....From HRE to Forgeline.
Some I probably should have had replaced I fixed. Some that could be saved I abandoned. There was no logic to it....it mostly depended on TIME. When did I need the wheel and how do I keep the schedule moving forward. |
The powdercoated fasteners might be a giveaway. That right? Did the shop powdercoat the entire wheel w/o disassembly?
Is it possible they cooked the wheels at a temperature high enough to warp them? Sherwood |
Those look like Jongbloed barrels to me.
| All times are GMT -8. The time now is 11:37 PM. |
