wareaglescott's Avatar
Pedal cluster part help please
Can someone explain to me where exactly this little part goes. It is part 21 in the below diagram. Part number - 901-423-193-00-OEM rubber stop.
I got a pedal rebuild kit of sorts from Pelican and I have this little part and really cant tell where it goes, or what it does. The diagram offers no help.
Thanks in advance!
Old 01-11-2020, 10:36 AM
proporsche's Avatar
isn`t that piece for right hand drive pedal cluster? Your pedal cluster looks like this i hope?The rubber ring should slide here as a stop..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 01-11-2020, 10:44 AM
I am pretty sure it’s 29 on the diagram.
If you google auto Atlanta Porsche and go to website they will show parts diagram for particular years.
The clicking on diagram will explode to show all part number side diagram.
Best way to check parts and #s and where they fit .
Gold71
It is 21. The part number on the bag corresponds to part 21 on the diagram.
Old 01-11-2020, 11:12 AM
Ivan
That must be it! Thanks so much
Part of my problem was when I took the motor out I forgot to disconnect the accelerator cable and that tab was bent back. Now I see I need to correct that as well so double thanks!!
Old 01-11-2020, 11:17 AM
Did this last winter and it is indeed 21 on the diagram.
21 is a rubber donut bumper that cushions the contact of the throttle bell crank. 29 is a nylon/bronze bushing which appears to back at the engine throttle assembly. Bob
Got it all fixed. Thanks everyone.
Once again I dont know how hobbyist did this stuff in the days before internet forums!
Old 01-11-2020, 11:40 AM
