License Plate Panel Paint
Say that 5 times heh..
Repainted my rear panel because P. O. put a dent in it as well as a deep scratch. Paint and clear went on smooth, no problems. After I ran the car awhile I noticed the paint starting to bubble (I assumed) from the heat radiated by the muffler. Not too bad at first but now almost the entire panel is bubbled. Did I miss something? I used quality RM paint as well as clear. Also painted the quarter panel extensions at the same time, no problems with them.
1973.5 911T ——-1974 914/1.8 Last edited by Artfrombama; 12-13-2019 at 10:50 AM.. |
ROW '78 911 Targa
Is there a heat shield missing?
Timmy2 has a valid question, there's a heat shield that rests in the bumper area to protect the paint from exhaust heat....
Scott "Houston, Tranquility Base here, the Eagle has landed" Silver 1984 M491 Sunroof Coupe |
There wasn't one when I got the car, was fitted with an aftermarket exhaust. I don't find one on any of the parts diagrams. Part number?
1973.5 911T ——-1974 914/1.8 |
RETIRED
Consider adding one or wrapping the muffler like the dragster guys do. Be advised the wrap retains moisture and can rot out a mild steel muffler.
You could always use a heat resistant paint or dip coat the muffler. Lots of options.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Under the radar
I thought the heat shield was an option? I have never seen one. Anyone have a picture?
Could it be caused by the aftermarket exhaust? My 73 has OE exhaust and no heat issues with rear panel paint. Rob
Stranger on the Internet
What kind of paint did you use?
Patrick E. Keefe 78 SC |
Painted 15 years ago - Did this just recently bubble? Or bubble slowly over time? Are you sure it's not rust bubbles underneath?
Cars and Cappuccino
Good question. Or is it possible something has changed with the engine (maybe oil flow) making it run hotter recently?
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
Cars and Cappuccino
Hard to tell for sure. Can you take pictures of the backside too? Good news is that panel is easily removed from the car. If you end up having it repaired and painted, it should not be a ton of money.
Just wondered if anyone else had a similar problem, if there was a part missing, etc. Looks like I have an incompatibility issue with the old/new paint. Thanks to those that responded, always appreciated!
1973.5 911T ——-1974 914/1.8 Last edited by Artfrombama; 12-16-2019 at 10:54 AM.. |
There should be insulation on the back of the panel.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
I have a 72 & there is no insulation between muffler & license plate panel. The only time I burnt the paint was when I had a burned out muffler and the exhaust was hitting the panel directly. Do you have any pin hole leaks in the muffler or gaskets?
68 Beetle 68 to 72 sold 72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army 67 VW split window 74 to 76 sold 81 VW caddy 81 to present |
Guy at the paint store said the panel was a replacement, was quickie sprayed with lacquer. Two stage polyurethane was not happy with the underlying lacquer.
The Insulation is nothing more than a thin flat sheet of asbestos type material glued to the back of the panel. You should be able to source some nd cut to size, otherwise you will be repainting soon.
There was a tar like undercoating sprayed to the backside of the panel, doubt if it was reflecting any heat.
1973.5 911T ——-1974 914/1.8 Last edited by Artfrombama; 12-19-2019 at 07:24 PM.. |
