LinkBack | Thread Tools | Rate Thread |
Rear Suspension, Sway Bar Adapter Kit for cars without a factory sway bar
Does someone has the dimensions for the clamps and spacers for Euromeister 65215676 911 Suspension,Rear Sway Bar Adapter Kit Weltmeister, for cars without a factory sway bar?
I guess the product is discontinued and I'm trying to build them by myself. ![]() ![]() ![]() Thank you.
I would just take a pair of calipers to the tube, and then guess the chromium yellow channels are about 3"...
jt '83 SC '96 M3 6 Bicycles 2 Sailboats |
I have an old pair without the bracket that connects it to the sway bar. That part should be fairly easy to fab or locate something that will work. I can sell them to you if you want to avoid having to make them. PM me if you're interested.
Marv Evans '69 911E |
