-   -   If you live at altitude is there a timing adjustment that would help? (http://forums.pelicanparts.com/porsche-911-technical-forum/104729-if-you-live-altitude-there-timing-adjustment-would-help.html)
IAN 04-01-2003 05:58 PM
I have a 72 2.4T.
I have heard that at altitude, folks prefer to set ignition timing at Top Dead Center versus 5 degrees before.
Any thoughts?
I live at about 4000 feet.
Thanks,
ian
Tyson Schmidt 04-01-2003 07:35 PM
Very highly recommended that you do. That T motor in your car is only 7.5/1 compression ratio. At altitude, it gets even worse. About the only thing you can do is advance the timing to help compensate.
I sure hope you're not wasting your money on Premium!
steveW 04-02-2003 02:01 PM
I live at 5000 ft (must be a honoury member of the 'Mile-High' club), I do know timing is adjusted for altitude, but can't remember which way it goes.
