IAN IAN is offline
If you live at altitude is there a timing adjustment that would help?
I have a 72 2.4T.
I have heard that at altitude, folks prefer to set ignition timing at Top Dead Center versus 5 degrees before.
Any thoughts?
I live at about 4000 feet.
Thanks,
ian
Old 04-01-2003, 05:58 PM
PRO Motorsports
Tyson Schmidt's Avatar
Very highly recommended that you do. That T motor in your car is only 7.5/1 compression ratio. At altitude, it gets even worse. About the only thing you can do is advance the timing to help compensate.
I sure hope you're not wasting your money on Premium!
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 04-01-2003, 07:35 PM
I live at 5000 ft (must be a honoury member of the 'Mile-High' club), I do know timing is adjusted for altitude, but can't remember which way it goes.
Steve in South Africa
If it isn't sideways, it isn't fun
Old 04-02-2003, 02:01 PM
