Do i need a clutch return spring
My 901 trans has a lug that is for a spring I'm sure. Its a 912 4 speed in my 911.
Is this a 912 thing or both. On removal there was no spring. I also can't find it anywhere . Thanks Lyndon
Vintage Owner
I don’t believe the 901 has a return spring on the clutch arm as it uses a push type pressure plate and a return spring on the clutch pedal assembly itself.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Lyndon |
The return spring number is 901.116.731.01. Refer to page R 59 in the factory 911 workshop manual, volume I.
Jon B. Vista, CA |
My 68 911 has a 67 s engine dated Sept 66 and the 4 speed is a Sept 65.
Lyndon |
But your 4-speed did originally have a spring, as evidenced by the pin on the bellhousing. The spring is still available new, in case you want or need one.
Jon B. Vista, CA |
Thanks. I will have look in he morning . I think my thrust was held in with a single set screw.
Lynddn |
I don't know what that means. The need for a coil spring depends on the version of bearing used, not the fork.
If you have volume I of the factory manual, refer to page R 59, it's fully explained.
Jon B. Vista, CA |
Here its called a thrust bearing. I don't have the manual. Will confirm in the morning
Lyndon |
I'll post a scan of the manual page tomorrow, unless someone else does first.
Jon B. Vista, CA |
Yes it's on the fork sorry. The bearing is still on the fork. A scan would be great thanks
Lyndon |
Please post a photo of your thrust bearing too...
Jon B. Vista, CA |
Will do
A quick photo of the factory workshop manual page.
See paragraph in upper right corner...
Jon B. Vista, CA |
![]() Looks like the later one not needing a spring |
