IAN IAN is offline
Need to install new Points in a 72, anything special I need to know?
I've never done this before.
I set the gap at .35mm or 0.014". Is it pretty straighforward to determine at which point during the rotation you should be checking the gap? Anybody have a quick photo, so I don't screw it up....
Should I set ignition timing, then set gap on points and then re-check ignition timing?
Thanks!
You guys rule.
Old 04-02-2003, 08:07 AM
you have it. the high spot on the dizzy cam should have the points at their maximum opening.
a .001" change in point gap is 2-3 degree timing change. check the timing again after a week or so. be sure to put a minimal amount of dielectric on the rub pad on the new points and the dust from the packaging can have detrimental effects. clean. clean. clean.
dwell meters are tricky on cd systems. i asked how to do it correctly on earlys, but it is lost in the swill of grey matter.
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 04-02-2003, 08:28 AM
