81 SC dying at speed
Sorry in advance for a longish question, however I'm working on a head scratcher of an issue on this one, and would appreciate any thoughts/help you all could lend while I try to chase this one down:
What it is doing (approx 3 times so far):
At highway speed, vehicle shuts off completely, with no warning. Meaning: cruising at 60-80 mph under power, then...nothing. No hesitation, no sputtering, no shuttering, no surging idle, not a thing...just off. Completely off. The only initial indicator is the sudden lack of engine noise, and slowing of vehicle. Note: the 3-4 cases of this doing it are days a part with NO driving on the days between.
What didn't work:
2 times popping the clutch while coasting restarted the vehicle and I continued on...not the 3rd time. Vehicle came to a rest, and turning the key resulted in starter turning over engine, no audible indication of engine trying to fire.
Roadside repair attempts and then started again:
After 5+ minutes and a few failed attempts to start it, I replaced the red relay and one random fuse for the blower motor that looked a bit worn. (doubt the blower was part of the issue, just addressing while in there) The car fired up on the first try and got me to work/home that evening with no further issues. Somewhat makes me think of vapor lock symptoms, but would that happen before it is at temp on a CIS vehicle?
Other thoughts:
This is now the 3rd red relay I've had in the car since fall. Replaced the first one after the vehicle wouldn't start after warm. Second one was replaced the other day when I started having these issues, now on the 3rd relay.
Conclusions/questions:
Seems to be either fuel or electrical, but where do I start with that wide range of variables. Concerned that it isnt likely that 3 relays all going bad...that there is an underlying issue that manifests (coincidentally) with the relay replacement.
Long story short: what do you all think I should start by further investigating/replacing/etc. Thanks so much for your help on this one!
Old 06-24-2019, 12:15 PM
walt's Avatar
Faulty ignition coil maybe. Checking the primary and secondary winding resistance may not help as you may have an intermittent short. If it's silver and made in Brazil just replace it but I don't think these were installed on SC's.
Walt
82SC 3.0
81SC 3.6
Old 06-24-2019, 12:20 PM
Thats a good point, I can check the coil, however I replaced it about 3 years ago with a Flamethrower. (Doesnt mean its not faulty, of course...)
Old 06-24-2019, 12:26 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Perma-Tune CDI box?
1981 911SC Targa
Old 06-24-2019, 12:33 PM
Mark Salvetti's Avatar
How to test rev limiter on SC (CIS)
Mark
1979 911SC Targa
Old 06-24-2019, 12:42 PM
Originally Posted by Mark Salvetti View Post
This is interesting...I hadnt considered, and of course I probably dont recall what RPM I would have been at.
Ignorant question. Suppose the limiter DID cut off ignition...would it have trouble restarting for some reason? Logic tells me that it should restart without issue, but you know what they say about logic and reason...
Old 06-24-2019, 12:48 PM
Still here
pmax's Avatar
The airflow safety switch at the back of the CIS metering assembly also cuts off the fuel pump by grounding the circuit (See pic in Mark's thread above How to test rev limiter on SC (CIS)).
Try disconnecting it temporarily to see if it is the culprit.
Old 06-24-2019, 12:54 PM
Have you checked fuse contacts? .. Maybe a critical fuse has poor contact. Happened to me, although I was not at speed; was about to park my car at a restaurant when engine just shut down. Nothing got it started. A few people helped me push it into a spot. I went inside, enjoyed a nice steak and a cab ... went out to the car and fiddled with the fuses, rotating some of them. Started up, no subsequent issues.
'79 911SC Targa
Old 06-24-2019, 12:57 PM
Verify the plug is secure into the CDI unit. Verify the green coax cable coming out of the distributor is not the culprit. With engine running, gently manipulate that little cable to see if the engine stutters or dies. Finally, what you describe could be the CDI unit itself. A common symptom of near failure is that it dies with some driving, but can restart immediately or after a short rest. Substitute with a known good CDI box to at least eliminate that as a potential problem. I have a loaner that I routinely provide to people for the cost of shipping to try/troubleshoot. --Bob
Old 06-24-2019, 02:06 PM
It doesn't matter what RPM you were at. When the module fails, it stops the fuel pump, regardless of the RPM you were running. It could happen at idle.
When mine failed, sometimes the car would immediately restart, but most of the time I had to wait a bit for things to cool for some reason.
Just unplug the white connector and see if the problem goes away. If it does, then you got off easy. If the problem continues, then you have more work to do.
Mark
1979 911SC Targa
Old 06-24-2019, 02:30 PM
Bob Kontak's Avatar
And it will sputter and die. OP is not experiencing this. Instantaneous engine cut out.
1981 911SC Targa
Old 06-24-2019, 03:09 PM
'78 911 Coupe
Mark is right. It's been a while but as I recall on restoration of a 78' SC, my rev limiter was defective. I disconnected it from the harness and the car ran like a top. My issue as a little different than mzavada; once you plugged the rev limiter back on, the fuel pump got no ground, hence no electric charge and the car would not even start.
Old 06-24-2019, 03:22 PM
Sure, at idle. But at speed, it's pretty abrupt.
Mark
1979 911SC Targa
Old 06-24-2019, 06:06 PM
Thanks everyone! You've given me a great list to start combing through!
I got myself organized tonight, and will start figuring these out tomorrow night!
Old 06-24-2019, 07:00 PM
Bob Kontak's Avatar
Mark
I have experienced it under acceleration. It's brutal.
Assuming just cruising and fuel pump cuts out it would be similar to the red relay breaking connection.
1981 911SC Targa
Old 06-25-2019, 05:05 AM
I maybe experiencing the same issue with my 82 engine. I don't believe I have a rev limiter since my car is a 77, but not sure about airflow safety switch. I am leaning towards the coil/CDI. Car starts up and runs great, idles smooth. I haven't driven it yet since the engine swap. About 20 mins when temp is up around 180-190, sputters, backfire, stalls.
Run it in your driveway for about 20 mins to see if it happens then. I have a feeling it will.
Old 06-25-2019, 05:40 AM
You got it backward.........
Brian,
The presence of a ground contact (terminal #85) in the FP circuit shuts off a running FP. Installing back the Rev limiter with an open ground to the car will have no effect to the pump (normal). The three (3) sources of ground for terminal #85 are:
1). AFS switch.
2). Rev limiter.
3). Car alarm/immobilizer.
You got it backward. Putting back a defective Rev limiter (grounded) will energize the NC (normally closed) 87a~30 to 87~30 (normally open) with the ignition switch @ RUN. The problem with your Rev limiter was it was grounded causing the coil inside the FD relay to switch off the FP.
Tony
Old 06-25-2019, 06:55 AM
Fahren mit dem Wind.
mhackney's Avatar
@mzavada - that "to do" list is over the top!
Keeper of the 1983 911SC Cabriolet Registry (http://911sccabrioletregist.freeforums.net)
Caregiver to:
1983 911 SC Cabriolet - Fahern mit dem Wind.
(Moss Green Metallic over Champagne and Brown Leather)
Old 06-25-2019, 07:11 AM
Timed it today. Idle in the garage. Everything smooth with warm up and settled around ~950. 21 mins in sputter, loss of idle, backfire, dies.
So I would say very similar to your issue. temp was up around 180 - 190
Old 06-25-2019, 02:51 PM
Cracked solder........
Mzavada,
Nditiz1’s CDI was sent to Bob Ashlock for evaluation. And Bob found a cracked solder @31/1 terminal. As the CDI warms up from the engine heat, the cracked solder opens up and lose ignition signal causing the motor to stop running. When the motor is allowed to cool, the cracked solder regains its contact back and allowing the CDI to operate again until the next cycle to shut off. Have your CDI tested.
Tony
Old 06-28-2019, 07:52 AM
