drag racing the short bus
RS door panel install - has anyone here done one?
How hard is it? For a novice, which I am.
The Terror of Tiny Town |
VERY easy. Only tricky part is the door handles. You have to drill into the metal door, insert some hardware that acts like a drywall anchor, and use a special tool (included with the kit from AppBiz) to expand the anchor. The tool doesn't always grab real well so this part of the job was a pain. I found it easier to make a small slit in the plastic liner and reach up behind the anchor to hold it and keep it from spinning. Make sure to tape up the liner afterwards.
Installing the speaker enclosures took a little time, but it wasn't difficult by anymeans. Again, door panels are an easy job. Anyone with a screwdriver can do it.
1983 911 3.6L - NASA GTS-3 class 1998 Boxster - PCA SpecBoxster, NASA GTS-2 2003 996X51 - NASA GTS-4, PCA GTB 2003 996 Carrera 2 Coupe 2003 Ferrari 575M |
Okay. Does it come with instructions of any kind?
Montana 911
yes...Bob @ appbiz was a great help.
Simple project can be done in about 30-45 min per door.
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
Check the technical articles on this site for instructions on removing the stock door panel. The kit from appbiz comes with a one page instruction sheet that details the few steps you have to do once the stock panel is off.
Hows the quality of the appbiz panel??
Montana 911
the parts I ordered are great quality (Handles and pulls)
I purchased marine grade vinyl and made my own panels...entire cost of the project was under $150
Smitty - It looks like I have to do mine in red, because my DAD seats are red. I may also have to go with red carpeting, though I don't think red carpeting is made in the RS style, perlon, etc.
How did you install the straps and door release functions? That's the hard part of the install, so I'm told.
Montana 911
it's pretty simple....with the panels off, attach the pulls with the nut/bolt provided. Also drill out the mounting holes for the handle and insert the anchors. Mount the panels, as you do this guide the pull strap through the panel and then simply secure the panel to the door with the clips. I have power windows so I had to guide the wires through as well...but this was a very simple task.
Montana 911
that is correct, they simply attach to the lever inside the door with a nut/bolt.
Make sure when you buy the you tell them you either want the RS or the RS America. The difference is in the door pull. The RS is a horizontal strap and the America is a vertical pull down. I installed the RS on my 76 and it required a little more work. I had to cut a whole and rig the door accuator with a cotter pin.
