-   -   Simple Oil Pressure Sending Unit Tip (http://forums.pelicanparts.com/porsche-911-technical-forum/104785-simple-oil-pressure-sending-unit-tip.html)
Rot 911 04-02-2003 05:08 AM
Since I have had my '86 Carrera the oil pressure gauge has always jumped around some and at any rpm's over 3K has stayed pegged at 5 bar. I have pulled the connector off and reconnected it on the sending unit several times without much change. Just wrote it off as a failing sending unit that I would replace when I pull the engine for a rebuild. Well I was in the garage last night puttering around and thought I would give the connections a good cleaning. I spent a couple of minutes with some fine emory cloth cleaning the contacts on both the sending and temperature units. This morning on the way to work the oil pressure gauge was not only rock steady, it smoothly showed an increase and decrease commensurate to the change in rpm's and no longer pegs out over 3K rpm's! You would think after years of futzing with British cars I would know the first thing you ever do when you have an electrical/gauge problem is clean the connections! Even on a 911!
BGCarrera32 04-02-2003 05:17 AM
Thanks for the tip. I pulled mine out last week as part of my grand plan and cleaned it. Perhaps I'll have a pleasant suprise when I reconnect it...
Some other connections that are somewhat hidden/overlooked that may be worth checking:
-ground connection behind fuel filter (hidden from view)
-connector block for fuel injection harness (behind heater blower up on bulkhead)
bigchillcar 04-02-2003 06:07 AM
Hey Kurt,
My oil pressure gauge started working erratically, pegging for no reason, etc. I did the same, cleaning with a fine wire brush all the connections at sender and behind gauge. I thought I was going to have to replace sender too, but all's well now.SmileWavy
Ryan
Early_S_Man 04-02-2003 09:42 AM
In addition to cleaning the male spade ... try dipping the female 1/4" Faston connector in vinegar for 3 - 5 minutes after degreasing it with Brakleen or a similar solvent, then rinse it off with distilled water. Crimp both sides slightly with needle-nose pliers ... but don't close the gap entirely! The connector should take significant force to install, and there shouldn't be any 'wiggle' at all after attaching to the male spade!
studeb 04-02-2003 10:10 AM
i prefer ketchup, then wash with water.
old_skul 04-02-2003 10:27 AM
Hell, Tabasco sauce will practically work as a metal etcher.
Good tip, Kurt. I'm going to give this a try on my 2-years-broke sender before I pop a new one in.
How do you remove that Faston fastener?
Superman 04-02-2003 10:36 AM
Ketchup has vinegar in it.
CrossT 04-02-2003 12:54 PM
ditto on the jumping and intermittently pegging at 5 bar ever since owning the car. cleaning the connection as well as redoing the wiring inside the connector took care of it right away. the connector just screws apart to reveal the connection to resolder. i love it when i fix something for no cost (and without breaking anything else in the process) :)
todd
=-=-=-=-86 cpe
Huey58 04-02-2003 01:55 PM
Where exactly is the sending unit on the engine so I can try and clean and fix my gauge problem?????
pwd72s 04-02-2003 05:22 PM
Huey, the sending unit for the pressure gauge varies from year to year. Your car is???
fogcity 04-02-2003 07:19 PM
I don't know about Huey's, but mine is a '84 Carrera. I posted a question about this same problem and after hearing how you can break the block during removal of the sending unit, I think I'd like to clean it and hope for the best. So, where do I find it?
CrossT 04-02-2003 09:37 PM
assuming the 84 is the same as my 86, it is poking straight up between the fan and the a/c compressor [if you have one] at the rear of the compartment [i.e., closest to you]. one wire leading to it. nice to have it steady. it was a bit annoying to constantly see that thing jitter. when it woud peg at the top it made an ittitating clicking sound as the needle would hit the stop. much nicer now.
todd
86 cpe
Huey58 04-03-2003 04:43 AM
Well I found the sensor and it has a black cap on the top
that the wire runs through. I have pushed, pulled, twisted
and yanked this thing with no success. Please tell me the trick
to get the cap off!
86' 911 Cab
BGCarrera32 04-03-2003 05:52 AM
The arrow on the right shows the pressure sensor for the gauge, the arrow on the left points down to the sensor for the idiot light. To remove the wire from the sensor, it has a hook clasp that grabs the post/contact it is secured to. You might need to hook the clasp with a small screwdriver and twist outward.
I've never heard of the block cracking from removing this and find it awfully hard to believe, but I suppose anything is possible...
-BG
http://forums.pelicanparts.com/uploads/sensorbdg1.JPG
dhoward 04-03-2003 07:33 AM
After cleaning and tightening, coat the connectors contact points with a conductive grease like Ox-Guard or Contax.
Huey58 04-03-2003 02:05 PM
BG!
You da man!!!
fogcity 04-03-2003 07:28 PM
Thanks, Bg
GermanLarrain 12-23-2012 07:26 AM
How to remove Sending Unit
Mine, was very tight, almost imposible to unscrew it. I decided to find a way to remove it with the less damage posible to the sender. I used 1 meter of 40mm (sorry but in Chile we used metric) PVC tube. Heat with warm water one end and insert it at the sender, actually copying the profile, so it could a better grab on it. To improve the grip I used a clamp, so I can tight it more. Voila....it works. see the pictures attached.
Hope this helps.http://forums.pelicanparts.com/uploa...1356279855.jpg
http://forums.pelicanparts.com/uploa...1356279892.jpg
http://forums.pelicanparts.com/uploa...1356279910.jpg
JJ 911SC 12-23-2012 08:42 AM
-BG
Arrow on the left is the Oil Temperature Sensor. The idiot light is on top in the Triangle of Death.
Jim Sims 12-23-2012 08:13 PM
The torque to dismount the oil pressure sender can be very high - enough that the reaction force at the fitting into the engine case can break off or strip the integral engine case threads (it has happened). It is far better to dismount the fitting (by removing the hollow bolt) and pressure sender, mount the fitting in a vise and then remove/replace the pressure sender. There have been numerous "rigs" made with crows foot wrenches, etc. (and now one with a "shrink fit tube") but none of them appear the address the reaction torque or force hazard.
dshepp806 12-24-2012 02:48 AM
No way would I attempt removal in 'situ...too much of a wrisk.
BEST!
Doyle
JJ 911SC 12-24-2012 03:48 AM
Yeah, it took 140 Psi to get it out of the block...http://forums.pelicanparts.com/porsche-911-technical-forum/594895-stuck-oil-pressure-sender.html
GermanLarrain 12-24-2012 11:11 AM
In the meantime
The sender was bad, full of rust, no way it can meassure something.
I order the new sender, unfortunatelly it takes a month to get to my country. I meassure the preassure and was OK (15 to 65 PSI). In the meantime, I built a plug out of the same sender unit (see picture).
Definatelly, I'll address the torque issue when istalling the new sender unit.
http://forums.pelicanparts.com/uploa...1356379811.jpg
dicklague 12-24-2012 01:39 PM
I just went through this. I could not get a 24mm wrench on the sender. Then I remembered the square block the sender screws into has a hollow banjo bolt through it. You loosen the second nut from the right 19mm and the whole assembly comes out. You could do real damage to the cases if you are not careful.
DO NOT put a lot of torque on that sender while it is in the car! As the poster above suggested take it out and put the brass block in a vise and then remove the sender.
