Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Difference in length between SWB and LWB banana arms?
Like the title says, does anyone know the difference between the two?
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 12-08-2019, 04:55 PM
2.5" as I recall.
206 637 4071
Old 12-08-2019, 06:43 PM
Shaun @ Tru6's Avatar
and there are two different geometries for LWB arms, 69-71 for 901/911 transmissions and 72-73 for 915.
Tru6 Restoration & Design
Old 12-08-2019, 07:15 PM
It's a 914 ...
stownsen914's Avatar
Also, at some poing in the early 70s, Porsche switched to cast aluminum for the trailing arms, and they are reputed to be stiffer. Maybe lighter too?
Old 12-09-2019, 06:24 AM
By my scales, lighter by about 13 lbs./pair.
I've also heard the claims to them being stiffer. I'll leave the rigidity claims to those who know better.
Sherwood
Old 12-09-2019, 08:28 AM
Rennch on YouTube
rennch's Avatar
I may go back to the original idea of just shifting my flares a little bit so the wheels stay centered.
Michael O'Neal -
Old 12-18-2019, 02:41 PM
kent olsen's Avatar
Years ago I had a problem with the left rear wheel bearing, in my 72. I ended up replacing the trailing arm with the aluminum item which apparently had a larger wheel bearing to boot.
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 12-19-2019, 09:43 AM
1QuickS's Avatar
The SWB trailing arms support the bearings FAR better than the LWB equivalents. The early RSR 911s needed to add stiffening plates to support the bearing housing on the steel bananas to prevent bending as a result of racing tires & large width wheels and the associated increased loading on the arms. The aluminum arms resolve that deficiency. Also, the bearing setup in the steel, LWB arms is a bit under-designed IMHO.
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 12-19-2019, 03:20 PM
