Rod installed on targa top?
The '88 Targa I had back in the late 90's had a threaded aluminum rod on the top that was installed by a prior owner. There were screws threaded into the front and rear of the frame that the rod fit over, and you'd just twist it until it lengthened and tightened up and pressed the frame against the seals. I honestly can't remember if it did much, but it probably did because I recall putting it in most of the time the top was on it. Has anyone else seen this done before? I searched the threads and didn't come up with anything. The recent threads about targa leaks and wind noise jarred my memory on this.
2018 Porsche 911 GT3 manual
1984 Porsche 911 Carrera Targa
2021 Porsche Macan GTS
2018 BMW R1200GS Adventure Rallye
2020 Ducati Scrambler 1100 Sport Pro
Old 12-30-2019, 12:31 PM
HarryD's Avatar
Sounds like a jury rigged fix to try to make it seal better. Top probably needs adjustment if is not bent from the rod.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 12-30-2019, 08:01 PM
