parts cleaners
time to rebuild the 930 engine.
most of the big parts have been cleaned and machined. but I am sick and tired of soaking parts then washing then off in the driveway. I soaked some bolts in carb cleaner and they aren't as clean as I want them. so I was considering an ultrasonic parts cleaner until I watched a video of some mods on the harbor freight solvent parts cleaners. the problem I have heard about with those is the water based solvents. this guy was using petroleum based solvent (psc1000) with good results. the problem with the ultrasonic cleaners is the size. but I saw this 10L (2.5gal) one on ebay. what do you think. I may get both. https://www.ebay.com/i/231401224730?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=231401224730&targetid=475515090941&device=c&mktype=pla&googleloc=9010587&poi=&campaignid=6469750693&mkgroupid=79220282802&rlsatarget=aud-622524042478 la-475515090941&abcId=1141176&merchantid=101676816&gclid=CjwKCAiAxMLvBRBNEiwAKhr-nE3LSwJw-eIhBzSVvjFB1ZFg1QnVGG-3zCOhmyvpzXgugTEWl4JdpRoCRHgQAvD_BwE
I'm good with tools.
My issue is that the solvent parts cleaners are good to get the muck and gunk off..... They don't actually get the part to a presentable condition. For that I suggest a vibrating parts tumbler.......
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
I don't have much left to clean.
I have the turbo oil pump and nuts and bolts mainly but I just ordered $80 in new hardware. https://www.belmetric.com/ what do you think of that ultrasonic cleaner on ebay. seems pretty cheap in price. I hate to get one too small
I haven't used a ultrasonic cleaner for auto parts......my wife uses one to clean her jewelry.
I'm no help on that.......
Ultrasonic cleaners are absolutely awesome, and have gotten ridiculously inexpensive. I'll clean virtually every internal transaxle part in my ultrasonic. However, NEVER use the ultrasonic for ball bearings or caged needle bearings. The balls/needles will etch a small imprint into the races.
PSC 1000 is a good first and second pass for cleaning. It absolutely eats through grease/oil/dirt that builds up. However, it doesn't do a great job with the more caked on stuff or stains. It's more for something like an oil leak would then get dust and dirt stuck in it and build up over time. That kind of stuff will come off with a light scrub with a wire brush. Also, you can't use the stuff sold in California, because that's a different chemical makeup. My buddy in San Diego used the stuff for a long time before moving there and says the stuff he can get is glorified water based solvents.
Jonathan '79 Copper 911 SC '88 White 911 Carrera- 98mm p/c with JE 8:1, Turbkraft EFI-T cam, Carrillo rods, Injector Dynamics 1050x, twin COP, AEM Infinity, twin Garrett GT2860rs's |
My fingers were raw from all the scrubbing, bolts, washers etc.
Purchased the Harbor Freight ultrasonic clear after recommendation from a friend. takes a bit of experimenting on length of time, strength of brew etc, but bolts/ washers etc come out looking amazing. |
look at this 30L cleaner.
wat I have and use as I guess may suit best:
- degreaser (gallon) - bakenoven cleaner (spray-on cans) - brake cleaner (rattle cans) - red rim-cleaner - paint stripper though all of these don't do their job fully without adressing the part with a brush or pressure washer to finish up I used an utrasonic bath for the throttle and the cold-start distributor (inside the SC airbox) as channels inside these parts were to small to poke free by hand)
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
the problem I had with the tumbler on such parts is all the residue it leaves on the threads. of course, scrubbing in the cleaning tank and bead blasting as a last resort.
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
New-ish 911SC Targa Owner
i've had good luck using Purple Power and Simple Green in my ultrasonic cleaner.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
I have the same one, with different name. It's a great unit. Can fit large pieces. It's annoying if you have to do few smaller parts as it would take so long to warm up the solution. |
I was looking at the 30L unit that was longer. I’ve used my harbor freight little jewelry cleaner for a lot of things including brake calipers. They are awesome cleaning tools and a larger unit would be amazing.
I would strongly recommend being careful with the cleaners you use. Some of the cleaners will corrode aluminum. People say you can use them but if your not careful you’ll get white corrosion all over that will not come off without blasting or sanding. I know the original simple green would and I only used the Aircraft Simple Green version. CTopher |
I was looking at these myself - but have not yet pulled the trigger.
Does anyone know if they would work on brake calipers - like these: Thanks!
Old dog....new tricks..... |
Get a basin type cleaner from Safety-Kleen. You will immediately know it's the best $400 you ever spent on tools.
Kevin Catellus Engineering catelluseng@gmail.com http://www.catellusengineering.com https://www.facebook.com/catelluseng/ |
CTopher |
Mighty Meatlocker Turbo
For Baz, and anyone else who doesn't already do this, you can seriously turbo powwwaahhhh your sonic washer brew by mixing in some cleaning vinegar - makes quick work of even the worst filth and corrosion on all metals, including magnesium. For steel parts, I use about 1/5 vinegar, relative to the rest of the solution volume (water and Simple Green, typically), and for aluminum and magnesium I use a little less (and keep a closer watch on the amount of time I leave the parts in the washer). When parts are removed, I typically hose them down with brake cleaner to remove water, etc., and then treat them with Corrosion X (unless they are parts that I'm going to paint - no Corrosion X then).
Baz, a mix such as that would work very well on your crusty, dusty, musty and rusty calipers, Bro!
personally ,the best i have seen cleaning Porsche parts is --rocktumbler....it is an amazing how clean it will be...the company Mr.Deburr......
I f you can find somebody locally who has it that would be the best solution.. Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
I got a 20 gal tank cleaner from HF.
so tank cleaner - check blast cabinet - check small ultrasonic cleaner - check small tumbler - check so what else dont I have and may need .....
