Fitting rear 1/4 window rubber
I’m really struggling to fit the rubber around the rear 1/4 window rubber ,I can’t even get it started in the frame ,does anyone have a way of fitting it
Thanks Brian
Old 01-04-2020, 08:18 AM
Harpo's Avatar
Bookmarked. I'm in the same boat as you
Old 01-04-2020, 12:57 PM
I’ve got them in all the way up to the hinged end but can’t get it to get on ,my fingers are killing me
Old 01-04-2020, 01:09 PM
Worst job I have ever done on a 911, I don’t have any tips sorry as I am sure there are better ways to do it than I did (took forever), just a message of support, I feel your pain.
Cheers,
Harry.
Old 01-04-2020, 05:23 PM
Hot bath, climb in with your window, keep the rubber hot and soft, soap for lube, and a plastic window stick to work the lip in 1/8" at a time.
206 637 4071
Old 01-04-2020, 06:31 PM
And if that doesn’t get it warm enough you’re welcome to work in my garage anytime between April and October
Old 01-04-2020, 07:11 PM
One complete and half of the remaining hinge side on ,cup of tea then try and get the other half of it on ����
Old 01-05-2020, 05:57 AM
(man/dude)
Jonny042's Avatar
Assume we are talking about 73 and earlier vent windows?
I tried 3 different brands of rubber for this and gave up on this job although it's looming in the near future as something that will need to get done.
My memory is a bit faint on it, I remember it being nearly impossible and when the rubber was stuck in the frame all around I still couldn't get it to stay in at the straight side. Very frustrating.
What brand of rubber seals are you guys using? I see Dansk is making them now so I think I'll try a pair of those next.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 01-05-2020, 06:23 AM
Troll Hunter
Did this last year on my 2002. Same type of rear window. John Walker is correct. The plastic 'window stick' is a must, but so is Dawn Liquid as your lube.
Thank goodness a (younger) friend of mine came over to help. It's murder on your (my old) hands and fingers and having 2 people helped. It takes considerable strength to push it into place.
I'd place reinstalling the windshield(s) as a worse job.
1978 SC Coupe, Gris Argent Metallic Silver
1988 FJ62 Blue/Gray
2020 M2 CS
Old 01-05-2020, 06:35 AM
