-   -   Short shift Kit - Broken Component (http://forums.pelicanparts.com/porsche-911-technical-forum/1048980-short-shift-kit-broken-component.html)
stevesc_us 01-03-2020 05:32 PM
Anyone out there know where I can get a replacement for this broken part in my short shift kit and what the piece is called? Thanks
http://forums.pelicanparts.com/uploa...1578101414.jpg
JohnTucker 01-03-2020 05:36 PM
The part is called the Shift Pivot Housing.
Have you asked Pelican if they might have it as part of a return or something?
stevesc_us 01-03-2020 09:17 PM
No I have not tried that yet, but will try your suggestion.
Thanks,
john walker's workshop 01-03-2020 09:40 PM
Weld it?
JohnTucker 01-03-2020 09:48 PM
Originally Posted by john walker's workshop (Post 10708064)
Weld it?
Yeah...what he said. Got anyone you know that can just weld it back together?
stevesc_us 01-04-2020 01:53 AM
Was thinking that as well, but if I can just find the one part to buy it will probably be no more expensive than the cost to pay someone to weld it. Still something to consider if sourcing a replacement part is not possible.
proporsche 01-04-2020 01:59 AM
try these guys ..i am sure they will have one for you
https://msroadrace.com/
Ivan
Joe Bob 01-04-2020 02:30 AM
Ivan
I wouldn't buy warm spit from that guy. LONG history of shady deals.
proporsche 01-04-2020 07:36 AM
i c ok, i only had good experience;-) times changed.....thanx for the info
Ivan
In that case look here these are nice guys on the east coast Ask for Roger or Matt
www.retroautomotiveproducts.com
Joe Bob 01-04-2020 09:45 AM
He used to be referred to as MS Road and RAPE....but that was 20 years ago when they still had swap meets in California. If it's under new management, I'll apologize.
Harpo 01-04-2020 11:21 AM
I have this if your interested
http://forums.pelicanparts.com/uploa...1578165586.jpg
JohnTucker 01-04-2020 09:50 PM
That looks like more of the stock part. The short-shifter assembly is much different. Not compatible.
Harpo 01-05-2020 06:07 AM
Yes the shift lever is stock, however the broken part would be a direct replacement
stevesc_us 01-05-2020 07:07 AM
Thanks Harpo. Just sent u a PM.
JohnTucker 01-05-2020 06:02 PM
I just installed the short-shift kit from our host about a month ago. As an experiment, I tried using the stock Pivot Housing just to see if it would work. It did not. You physically can't shift. The short-shifter Pivot Housing and VERY different from the stock. FYI.
JohnTucker 01-05-2020 06:05 PM
If you look closely at the OP's pic...you can see it matches the the part in this link:
https://www.pelicanparts.com/More_Info/91142493100OEM.htm?pn=911-424-931-00-OEM&bt=Y&fs=0&SVSVSI=911M
Definitely not the same as the part Harpo is showing in his pic. It won't work. Sorry.
stevesc_us 01-05-2020 09:14 PM
Thanks JT. Appreciate you looking at this closer. Looks like my search continues then.
