Short shift Kit - Broken Component
Anyone out there know where I can get a replacement for this broken part in my short shift kit and what the piece is called? Thanks
1970 914-6 #2615 (Metallic Green) - SOLD
1974 911 US Carrera Coupe #63 (Lime Green)
1973 911 T Coupe #1891 (Gemini Blue)
Old 01-03-2020, 05:32 PM
The part is called the Shift Pivot Housing.
Have you asked Pelican if they might have it as part of a return or something?
Current:
1984 911 Targa Whale Tail "Gemma"
2014 Boxster S (wife) "Sir Jenson" (She named it...not me)
Previous GF's - 986 Boxster S, 987 B Cayman, 981 B Cayman, 981 GT4
Old 01-03-2020, 05:36 PM
No I have not tried that yet, but will try your suggestion.
Thanks,
Old 01-03-2020, 09:17 PM
Weld it?
206 637 4071
Old 01-03-2020, 09:40 PM
Originally Posted by john walker's workshop View Post
Weld it?
Yeah...what he said. Got anyone you know that can just weld it back together?
Current:
Old 01-03-2020, 09:48 PM
Was thinking that as well, but if I can just find the one part to buy it will probably be no more expensive than the cost to pay someone to weld it. Still something to consider if sourcing a replacement part is not possible.
Old 01-04-2020, 01:53 AM
proporsche's Avatar
try these guys ..i am sure they will have one for you
https://msroadrace.com/
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 01-04-2020, 01:59 AM
RETIRED
Joe Bob's Avatar
Ivan
I wouldn't buy warm spit from that guy. LONG history of shady deals.
2012 ML350 3.0 Turbo Diesel
Old 01-04-2020, 02:30 AM
proporsche's Avatar
i c ok, i only had good experience;-) times changed.....thanx for the info
Ivan
In that case look here these are nice guys on the east coast Ask for Roger or Matt
www.retroautomotiveproducts.com
Old 01-04-2020, 07:36 AM
RETIRED
Joe Bob's Avatar
He used to be referred to as MS Road and RAPE....but that was 20 years ago when they still had swap meets in California. If it's under new management, I'll apologize.
Old 01-04-2020, 09:45 AM
Harpo's Avatar
I have this if your interested
Old 01-04-2020, 11:21 AM
That looks like more of the stock part. The short-shifter assembly is much different. Not compatible.
Current:
Old 01-04-2020, 09:50 PM
Harpo's Avatar
Yes the shift lever is stock, however the broken part would be a direct replacement
Old 01-05-2020, 06:07 AM
Thanks Harpo. Just sent u a PM.
Old 01-05-2020, 07:07 AM
I just installed the short-shift kit from our host about a month ago. As an experiment, I tried using the stock Pivot Housing just to see if it would work. It did not. You physically can't shift. The short-shifter Pivot Housing and VERY different from the stock. FYI.
Current:
Old 01-05-2020, 06:02 PM
If you look closely at the OP's pic...you can see it matches the the part in this link:
https://www.pelicanparts.com/More_Info/91142493100OEM.htm?pn=911-424-931-00-OEM&bt=Y&fs=0&SVSVSI=911M
Definitely not the same as the part Harpo is showing in his pic. It won't work. Sorry.
Current:
Old 01-05-2020, 06:05 PM
Thanks JT. Appreciate you looking at this closer. Looks like my search continues then.
Old 01-05-2020, 09:14 PM
