Fitting rear 1/4 window rubber
I’m really struggling to fit the rubber around the rear 1/4 window rubber ,I can’t even get it started in the frame ,does anyone have a way of fitting it
Thanks Brian |
Bookmarked. I'm in the same boat as you
David |
I’ve got them in all the way up to the hinged end but can’t get it to get on ,my fingers are killing me
Worst job I have ever done on a 911, I don’t have any tips sorry as I am sure there are better ways to do it than I did (took forever), just a message of support, I feel your pain.
Cheers, Harry. |
Hot bath, climb in with your window, keep the rubber hot and soft, soap for lube, and a plastic window stick to work the lip in 1/8" at a time.
And if that doesn’t get it warm enough you’re welcome to work in my garage anytime between April and October
One complete and half of the remaining hinge side on ,cup of tea then try and get the other half of it on
(man/dude)
Assume we are talking about 73 and earlier vent windows?
I tried 3 different brands of rubber for this and gave up on this job although it's looming in the near future as something that will need to get done. My memory is a bit faint on it, I remember it being nearly impossible and when the rubber was stuck in the frame all around I still couldn't get it to stay in at the straight side. Very frustrating. What brand of rubber seals are you guys using? I see Dansk is making them now so I think I'll try a pair of those next.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Troll Hunter
Did this last year on my 2002. Same type of rear window. John Walker is correct. The plastic 'window stick' is a must, but so is Dawn Liquid as your lube.
Thank goodness a (younger) friend of mine came over to help. It's murder on your (my old) hands and fingers and having 2 people helped. It takes considerable strength to push it into place. I'd place reinstalling the windshield(s) as a worse job.
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
