OK, what do you think - 79SC 'tinkling' noise on accelration
Hi folks, this is a Euro 79 SC targa with a relatively recent top end rebuild by a good guy and several 1000 trouble free miles since, valve settings and timing in spec when last serviced, with stock heat exchangers, a cat bypass and aftermarket muffler.
I am hearing a pinging/tinkling noise from the engine when I accelerate, most noticeable in lower revs in 3rd, it most sounds like the noise a patch of gravel makes when it pings off the wheelarch and muffler. That is what I thought it was at first but it happens when there is no road debris at all. It goes away at higher revs. The car is driving normally otherwise.
I don't think this is detonation (I don't really know what that really sounds like though) and it doesnt sound shut-the-motor-off-right-now bad, but I don't want to do any damage if it is an early sign of something - any suggestions?
TIA.
65 356C, 78 928 5 spd, 79 911SC Targa, 89 964 C4, 99 996 Turbo, 03 Cayenne S
Old 01-13-2020, 05:11 AM
Slippery Slope Expert
Steam Driver's Avatar
That sure sounds like pre-ignition to me. Maybe you got a batch of sub-standard fuel?
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.”
Old 01-13-2020, 05:48 AM
l_turn9's Avatar
As Steam Driver suggested, maybe substandard fuel. I assume you are using the highest octane fuel available in your area? That's what your 911 needs to prevent Pinging.
Old 01-13-2020, 06:42 AM
Detonation is a very bad thing.
The 911 3.0 and 3.2 engines (and the earlier engines) don't have any knock sensors. It is easy burn a hole in a piston with pinging. Check your timing advance but even more important, be sure to have good premium fuel in the tank. Running regular is a way to destroy the engine trying to save a few bucks on a tank of gas.
Old 01-13-2020, 06:52 AM
That's exactly what my motorcycle sounded like when I got gas from a certain station. I assumed they were doing something fishy with their premium fuel, like not actually having any on hand...
Old 01-13-2020, 07:10 AM
Thanks for the responses. It could well have all been on the same tank of gas thinking back. I'm going to re-check timing and switch to better fuel, I'll report back - it may be a while as the salt is really going down here after a mild winter so far.
Old 01-13-2020, 12:02 PM
