-   -   Convex side mirror (http://forums.pelicanparts.com/porsche-911-technical-forum/1049095-convex-side-mirror.html)
maktarga 01-05-2020 07:38 AM
Convex side mirror
Is there a convex passenger side mirror prong-type option for my '86? Thanks
milnejk 01-05-2020 08:15 AM
Would be interested also. Thanks!
kent olsen 01-05-2020 08:36 AM
I put one on my drivers side, not a stock mirror. I wanted something to give me more side vision while on the track during a track day. It does that, but what I don't like is everything looks smaller and unless the car is close it's hard to distinguish.
john walker's workshop 01-05-2020 08:45 AM
My harley came with those things. Talk about unsafe. 1st thing that got replaced. Nice to know exactly where that car is, rather than have to guess.
maktarga 01-05-2020 10:06 AM
Where did you get the mirror from? How did you mount it?
darrin 01-05-2020 02:39 PM
check out these guys -- https://www.only944.com/partscatalog/only/mirrors/mirror944/
944 flag mirrors use the same size glass as 911 flag mirrors -- these guys sell convex glass which you can glue over your flat mirror glass OR, carefully pry the flat glass off the mounting backing and replace (the better option as the glue holding the mirror glass onto the backing becomes brittle and fails with age
Lyle O 01-05-2020 03:33 PM
I bought one from our host 4 or 5 years ago; not sure this is the same, but it is listed here.
https://www.pelicanparts.com/catalog/SuperCat/911M/POR_911M_BDYEXT_pg5.htm#item9
GH85Carrera 01-06-2020 06:41 AM
I bought a stick on wide angle mirror 24 years ago and after 100,000 miles and temps from 0 to 121 F it has been a stick on and forget it thing. Even when the mirror heaters are on it sill melts ice off of the mirror just fine. I think I still have the information of where I bough it all those years ago.
It was a super simple install. Clean the old mirror, peel and stick. Ta Da.
maktarga 01-06-2020 07:54 AM
Thanks a lot guys!
DNickel 01-06-2020 11:54 AM
I bought this from Burco Redi-Cuts.
I just double sided taped it as I didn't want to ruin the heated mirror if I broke something trying to retro-fit.
Works like a charm.
3 11/16 X 6 9/16
6 7/8 dg
#3614
Convex
Non-heated mirror
Fits heated OE mirror only
maktarga 01-11-2020 06:52 AM
Works like a charm.
3 11/16 X 6 9/16
6 7/8 dg
#3614
Convex
Non-heated mirror
I ordered it. Let's wait and see. What kind of tape did you use?
darrin 01-11-2020 07:22 AM
mak -- I'd first make sure your existing mirror glass is still SECURELY fastened to its backing -- had my original passenger mirror glass literally fall off its backing at a stop sign a few years ago -- chain only as strong as its weakest link, etc.
FrenchToast 01-11-2020 02:47 PM
Convex passenger side mirror was made standard in MY1988 or 89. One of those, don't remember.
It's listed in the PET.
speednme1 01-12-2020 06:10 PM
I had a couple for sale but they are sold now. The part number is on my ad http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1036333-fs-nos-convex-mirrors-flag-door-mirror-housing.html
DNickel 01-13-2020 11:58 AM
I have an '88 with plain glass so most likey '89
I used think double sided tape with a foam core. It's probably no more than 1.5 mm thick.
