993 ac belt question
Hi all,
I changed the belts on my 1996 993 (2wd coupe) yesterday. I used the ContiTech belts sold by our host.
The fan belt fit perfectly.
The alternator belt fit; I had to go down to a single shim between the pulley halves, but it fit.
The AC belt seems to be too tight- had to remove all the compressor mounting bolts to get it on, and then it took a good pull to get the last bolt in the hole. I was able to get it on there, and the bolts are in and tight, but there is no adjustment on the adjustment screw and it is rather tighter than the other two. It deflects a few mm under finger pressure, but it's a lot longer belt than the other two and I expect more deflection. Seems like potential to wear the compressor bearings and/ or reduce belt life.
Anyone else seen this? Am I just being paranoid? Should I have used the Porsche part?
Are there two different ac belts for this car? I ask because the AC compressor doesn't mount directly to the bracket- there is a little intermediate aluminum platform - maybe 1/2" tall- that goes between the two. With that removed it seems the belt would probably fit, with some tension on the adjuster.
Thanks,
Dan
Sent from my Nokia 7.1 using Tapatalk
Old 01-08-2020, 07:38 AM
Red Line Service
Marc Bixen's Avatar
A/C belts are always tight, but a non-factory alternator belt may be an issue. If you get a check engine light for mis-fire, throw the Conti belt in the trash and put a dealer alternator belt on it.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 01-08-2020, 07:30 PM
Well, that was spot on. Alternator belt already broke. Maybe put 200 miles on it. What a piece of junk.
AC belt is now upside down. Will that recover or should I replace that again too?
Dan
Old 02-13-2020, 03:17 PM
F
Old 02-13-2020, 03:43 PM
