Seat belt/Brake light warning cover
I am trying to find a part number to the seatbelt/brake warning light plastic lense in an 85 911. Found mine in 2 pieces lying on the floor. The lights work, it just looks like the cover split in half and fell off.
Or maybe someone has one laying around. Thanks
Dan T '85 Carrera Dansk premuff/sport muffler 7's and 8's, Steve W chip Kuehl AC and fresh top end |
Thread Killer
Common problem. Super glue is a temporary fix. Although NLA from Porsche, ask in the classifieds, they seem to be fairly readily available.
Allen '85 911 Coupe '75 BMW 2002 '02 Ducati Monster 900ie '18 GMC Sierra Denali 6.2L 4wd |
Rescuer of old cars
Lens was never available separately. Part number for the light assembly is/was 944.632.213.00.
I sold my last NOS unit about a year ago.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Analog Air Cooled
Does this unit pull right out of the dash and not from behind? I have the same one and my seatbelt light packed it in.
86 Targa 91 964 13 6 SPD Cayenne |
Thread Killer
Unit is removed from the front, but the retaining tabs must be released from the back.
Analog Air Cooled
Ah ha. Thought so.
Analog Air Cooled
With the radio out can you reach behind or do you have to pull a panel? I’m wondering if I can pull it out, perform surgery, and possible replace the burned out light on the board.
You dont have the remove the whole thing to get the lense off, it will pry off with it installed. Using a pair of pliers, you can remove the bulbs
But if you want to pull the whole thing out, you can access by removing the clock.....reach in with a small screw driver to release the tabs on top and you should be able the push the unit out ever so slightly from there you should be able to work it out from the front. You can not get it by removing the radio.
1983 911SC 1977 930 Turbo (again) 2018 GTS 2023 Audi A4 '74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone) Last edited by stevie 77 930; 01-12-2020 at 12:50 PM.. |
If you find a source for them, let me know. Haven't been able to find an yew ones for years. There are a few on E-Bay periodically for stupid money.
2002 GMC Yukon SLE - 4AT - Purchased New in 2002 1988 911 Cab - 5MT - Purchased Used in 2005 2008 Cayman - 5MT - Purchased New in 2007 2014 911/50 - #1173 - 7MT - Purchased CPO in 2014 2019 Macan S - 7PDK - Euro Delivery/New in July 2019 |
The cover comes off with the unit in place. 2 very small nipples, top and bottom. I super glued my broken cover and it snapped right back in. Can't see the break or the fix as it was on the long seam.
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Lens.
Have a look on the used parts forum.
I bet you will find one. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
