Jerky low speeds 3.2 carrera
Hi All,
I have a fairly stock 3.2 Carrera with a Wong chip and M&K exhaust, when slowly creeping forward in 1st or 2nd gear the car can be quite jerky sometimes. The only way to stop this is to put foot on the clutch and coast. It's those scenarios where I am wanting to go 5-10kph and creep forward. Is this a symptom of bad driving or perhaps something mechanical? |
Stall speed on these engines is quite high, so yes, as you slow to a stop you have to engage the clutch early.
Eine Garage ohne Porsche 911 ist nur ein dunkles Loch - Walter Röhrl |
I noticed the same thing. I think it's just a "that's how it works" situation.
Yep. It's normal. You just get the feel for when you need to depress the clutch.
-Vince '10 Carrera S '88 Carrera Targa (sadly sold) |
1988 3.2, the same. It doesn't like low revs in 1st or 2nd gear. That's why I don't like driving in heavy traffic. I always thought that the engine was loading up and I would rev to clear but it didn't make any difference.
1988 Carrera coupe 1966 250 Ducati 2015 VW Golf TDI gone because Dieselgate! 2021 VW Golf TSI 2014 Ninja 300 |
Driver, not Mechanic
How low do you guys let it go? I’ve rarely experienced this, but maybe because I cut my teeth driving a Beetle...
Yep.
They aren't very good town cars. First gear is very high and they don't like low rev's. Especially laboring at low rev's. My SC tend to be "We're off, stop, we're off, stop..." etc. Hard work in walking pace traffic. |
Thanks all, good to know it's not just me! I had an SC prior which felt a bit better at low speeds in traffic so thought something might be up.
OK, and I was about to open up my AFM to try to fix this 'problem', but apparently it is normal behaviour. Very annoying anything lower than 25 km/h (15 mph) is an issue on mine (85 Carrera)
They have a fuel cut out when the engine is above 1300rpm and the throttle is closed that may contribute to the jerkiness. I also recall posts suggesting wear on the resistor track of the AFM makes them worse.
EDIT: Found one: [3.2 Motronic] Air Flow Meter wiper arm re-tracked - WOW! PS. My 3.2's have never liked low speed running either |
My '85 was pretty bad, but installing a Steve Wong chip helped it considerably. The '88 isn't quite as bad, but it's there. No chip yet so I can't say if it'll improve.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
That's fond- just deglaze
Hi cafe_racer- I did notice a sizeable improvement in low-speed operation once I retracked the AFM. Here's my story...
Air Flow Meter Adjustment!
Missed Approach Petra- 1986 Coupe |
I'm good with tools.
x2
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
Diss Member
My 87 had issues with jerking and surging at low RPMs until I went through it and replaced the intake gaskets, intake spacers, a whole bunch of dried and hardened old rubber, and had the DME's solder joints reflowed.
Since then the car will smoothly crawl along at idle.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Still here
I agree with the others yours might have a vacuum leak. |
I would not agree that this is normal. I had similar issues when I got my ‘85. Through all of the research, etc... I learned about the “Barndoor” AFM. The contact wiper wears a path in the mating piece (the air flow is measured by how far the “bar door” opens, and that position is reflected through a variable resistance (?) strip. Much like old R/C car speed controllers). By changing where the contact arm “wipes” this surface - you can smooth things out considerably.
I’m sure there are better words to describe the components I describe - but this is the experience that I had. I did find a procedure for opening and adjusting this somewhere. May have been in the 944 forum. The Motronic system uses this type of air flow measurement. Not discounting vacuum leaks, bad sensors, and the like. Don’t accept a car that bucks and stutters. These things should be smooth. Good luck. |
Does the jerkiness occur even after the motor is warmed up? In my experience, the jerkiness -- actually a pretty violent bucking -- caused by worn track in the AFM was basically a cold engine phenomenon.
I agree that your should run smoothly at low rpms.
1988 Carrera Coupe (3.2) 1987 Ferrari Mondial 1976 BMW 2002 |
Diss Member
(They hadn't leaked a drop either.)I knew the intake gaskets were leaking but when I pulled the manifold off I was surprised to find that the plastic manifold spacers had eroded too. Fixing all of the above really smoothed it out but I also had the DME reflowed and while I was in there I replaced the 24-pin chip with the last factory 28-pin chip. That made it idle better then it had when I bought it at 110K miles back in 99. The DME needed the reflow but the 28 pin chip upgrade raised the idle from 800 to 880 rpm which would make some difference. I really feel that absolutely eliminating all vacuum leaks was the biggest fix. It really brought it all together.
I had a similar issue before replacing the ICV and addressing a couple vacuum leaks.
Sent from my iPhone using Tapatalk |
