-   -   Installing a 915 on a 69’ 912 (http://forums.pelicanparts.com/porsche-911-technical-forum/1049724-installing-915-69-912-a.html)
lrodri64 01-11-2020 05:48 PM
Hi,
Any tip / advice on how to install a 915 on a 1969my 912 ?
Thanks in advance.
lrodri64 01-11-2020 05:49 PM
I need to know which pressure plate I have to use.
john walker's workshop 01-11-2020 06:03 PM
You have a push clutch, so the only 915 that will relate to that is a 76 912e one. May still have some t/o bearing interface issues, never tried it.
bkreigsr 01-13-2020 12:21 PM
And even with that, the 923 trans from the 912E will not work with 915 running gear. You need a VW input shaft and clutch/flywheel package for 215 mm components.
Bill K
john walker's workshop 01-13-2020 03:18 PM
The 912e trans has a vw size mainshaft.
lrodri64 01-14-2020 09:23 AM
Hi again.
I explained to my customer all the pro’s and con’s for doing that and now we are back in the market for a 1969 5speed 901.
Thanks.
jpnovak 01-14-2020 09:49 AM
There is a rebuilt 901/13 in the classifieds right now. Correct with 6:29 CWP.
Worth a look.
flyingjay 01-14-2020 09:53 AM
I believe I have a 69 912 transmission. I can check when I get back to the shop
Matt Monson 01-15-2020 05:13 AM
Worth a look.
I’m going to assume the reason his client thinks he wants a 915 is they are adding power and need strength. The 6:29 (stock for a 69 912, but not stock for the 901/13) is weaker than the standard 7:31. Porsche used them for hill climbing and rally back in period and would toss them after one race weekend. I would be looking for just a plain stock 901/13 and then strengthen it with a new bearing plate and side cover.
