#147 of 2096
Installing a 915 on a 69’ 912
Hi,
Any tip / advice on how to install a 915 on a 1969my 912 ?
Thanks in advance.
#147 of 2096
Old 01-11-2020, 05:48 PM
#147 of 2096
I need to know which pressure plate I have to use.
#147 of 2096
Old 01-11-2020, 05:49 PM
You have a push clutch, so the only 915 that will relate to that is a 76 912e one. May still have some t/o bearing interface issues, never tried it.
206 637 4071
Old 01-11-2020, 06:03 PM
cycling has-been
bkreigsr's Avatar
And even with that, the 923 trans from the 912E will not work with 915 running gear. You need a VW input shaft and clutch/flywheel package for 215 mm components.
Bill K
Old 01-13-2020, 12:21 PM
The 912e trans has a vw size mainshaft.
206 637 4071
Old 01-13-2020, 03:18 PM
#147 of 2096
Hi again.
I explained to my customer all the pro’s and con’s for doing that and now we are back in the market for a 1969 5speed 901.
Thanks.
#147 of 2096
Old 01-14-2020, 09:23 AM
I would rather be driving
jpnovak's Avatar
There is a rebuilt 901/13 in the classifieds right now. Correct with 6:29 CWP.
Worth a look.
Old 01-14-2020, 09:49 AM
flyingjay's Avatar
I believe I have a 69 912 transmission. I can check when I get back to the shop
Old 01-14-2020, 09:53 AM
gearhead
Worth a look.
I’m going to assume the reason his client thinks he wants a 915 is they are adding power and need strength. The 6:29 (stock for a 69 912, but not stock for the 901/13) is weaker than the standard 7:31. Porsche used them for hill climbing and rally back in period and would toss them after one race weekend. I would be looking for just a plain stock 901/13 and then strengthen it with a new bearing plate and side cover.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 01-15-2020, 05:13 AM
