How to design a X-pipe for 911 with RSR cams
As the heading says, I want to challenge you all to come up thoughts about how to come up with the best x-pipe design for a 911 with RSR cams.
Run discussion
Bill Verburg, Steve Weiner, others....ideas, thoughts ?
Old 01-11-2020, 10:15 AM
What's an X pipe?
Old 01-11-2020, 10:18 AM
Courtesy of fellow Pelican, hee's a pic ...
X-pipe is a merge between right and left bank exhaust to custom the exhaust sound, like the one in the picture. It means that left and right exhaust bank has a hole/opening in the bend where they are welded together. This blends the exhaust in a way that alters the sound to the better..
Old 01-11-2020, 10:23 AM
Bill Verburg's Avatar
Run discussion
It depends on the noise restrictions that you need to live w/
In general the best performance from an even fire engine like a porsche flat 6 is 2 separate sides or a tri y type that spreads the torque out a little bit. An x on these types of engines will also dissipate noise a bit better.
The best quiet system is a separated catless 993 type
like this, I used 993 turbo side mufflers instead of n/s 993 side mufflers because they are a better design that flows better. On a 911 w/ the right rear oil tank this won't fit
so 3 to 1 headers make for a very efficient design, size depends on the engine size and rpm design range, you almost have to use a rear mounted muffler and the bigger the case the more sound absorption will be had. I like the idea of redesigning the interior of a stock banana muffler though the factory design is fine too. I wouldn't join the 2 sides, I'd have parallel opposite flowing perforated internals as long as possible w/o bends in them.
You want the pipes to terminate in as large a cavity as possible to generate as large a return signal to the valves as is possible to get, a bell shaped exit helps, the perforated pipe would be wrapped w/ f/g or ss wool.
This partially shows why a x over on these engines isn't desirable form a performance perspective, if you look at the valve events on any one ide they are separated by 180° from the same event in an adjoining cylinder, looking only at the exhaust events E1 ends 180° before E2 which ends 180° before E3, the exhaust events are an asymmetric blob of hot gases that rapidly move through the pipe leaving a partial vacuum behind them. The enter the collector w/ a small vacuum at the tail which helps to suck the next blob into the collector and and then repeat. When the sides are connected this sequence is disrupted, it can be a positive or a negative depending on the detail and rpm(timing of the gas blobs) but if implemented it has to be done carefully as w/ the design of the dollector itself, the gases have to be gently merged together
Exhaust events are orange, others colors are intake or internal events that don't generally concern the exhaust
Bill Verburg
Old 01-12-2020, 09:56 AM
Very well explained, thanks. Bob
Old 01-12-2020, 12:34 PM
Old 01-12-2020, 12:45 PM
Thank you for a very well explained answer Bill.
I found this, what do you think of it?:
https://m.youtube.com/watch?v=kjo9MWSpuZA
And what do you think of a silencer like this, made without merging in the X?:
Old 01-13-2020, 02:36 AM
Eva
911SauCy's Avatar
I'm with Bill (LOL)!!
I've had countless discussion with people smarter than me about the highest possible flow exhaust configuration for my car...
X-Pipe is always shy'd away from as I understand they can even lower horsepower.
But man a stinger or straight X-pipe does surely sound the business
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 01-13-2020, 05:16 AM
Send a message via Skype™ to KNIGHTRACE
I have a muffler made bu dynomax 17231 that I enter in the top and exit the top on one bank, other bank enters lower and exits lower. Works very well on big cams, William Knight
Old 01-14-2020, 10:02 AM
THis is the only properly designed exhaust for a 9111 that I have ever seen which merges the 2 sides
All Jaguar, BMW, MB etc straight 6s do it like this but w/ fewer bends and a longer fetch to implement it in.
To do the same on a 90° V8 w/ a 90° requires either this
or this
for 4cyl engines which are also even fire this is common, this Tri-Y gives a broader torque spread than the 4 into 1 design
as is this
Bill Verburg
Old 01-14-2020, 01:11 PM
