Smile you have a Porsche
Shift knob adapter?
Hi guys, I installed a Rennshift shifter on my 69 911E, I have a 901 and did not want to go with the Wevo as I would have to buy a 915 shifter base.
I did purchase a Wevo press fit shift knob, how do i install it on my Rennshift column which has female threads?
Any ideas, If not I will machine something.
Regards
John
Old 08-21-2013, 03:30 PM
could you not use a tap on the shift knob?
Old 08-21-2013, 03:36 PM
Hi, no the shift knob is a press fit to be used with a crush washer. The column has a female thread.
Regards
Old 08-21-2013, 03:41 PM
Go-Kart Mozart
JAR0023's Avatar
According to the JWest website their shifter is set up to use their shift knob or a factory shift knob. That WEVO shift knob is set up to mimic the stock knob/crush sleeve combo. Double check the diameters of your new vs. old shifters. It sounds like you can just install the Wevo shift knob with the crush sleeve just like you would install it on a factory shifter. -J
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 08-21-2013, 05:55 PM
I am bumping this thread up as I have the same issue. A threaded Wevo shifter with a press on knob with the crush sleeve.
Anyone have a solution?
Old 01-16-2020, 08:56 AM
The 9 Store
I bought a stainless steel bolt with the same threads as the lever and used 5 minute epoxy to secure the head of the bolt inside the knob ( it’s a turned 917 style wood knob) used a stainless steel washer to keep the wood from getting crushed on the shaft. Less than $3 at Home Depot and it looks perfect.
Interior sans carpet
All used parts sold as is.
Old 01-16-2020, 04:26 PM
Flojo's Avatar
I like the hwo-need-carpet-anyway style
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 01-17-2020, 01:34 PM
