Analog Air Cooled
Hotshot's Avatar
Hi beam flasher ( pull back ) question.
Has anyone had an issue where there turn sig work perfect, low beam, high beam work perfect, but the flasher or when you pull back, doesn’t do a thing?
I have a Momo she’ll the PO installed, before I dive in and look at the switch I’m curios to here your thoughts.
I tried searching it but didn’t find flasher only type threads.
Thx
86 Targa
91 964
13 6 SPD Cayenne
Old 01-15-2020, 06:19 AM
The factory did not put a relay on the headlights as they should have. If your car has never been upgraded with a relay for the headlights, all the voltage for headlights goes through that switch and burns them up with use. The fix is of course to add the headlight relays, and replace the switch.
When I first got my 911 back in 1995 it was a 10 year old car and not driven much at night. The switch quit working withing the first few months of my ownership. I replaced the switch, added the relay harness, and after 25 years and 100,000 miles of additional driving, the headlights work perfect.
There are threads on Pelican about how to take the switch apart and clean the contacts and some people have luck with that, many don't. Just do it right and one time. Replace the switch, look on Pelican for the headlight relay kit, add that and fix it once and forever.
Old 01-15-2020, 06:40 AM
1988 Carrera
shadowjack1's Avatar
This
88' Carrera
79' SC gone (lost to Katrina)
75' Targa gone
72'914 gone
72' 914 gone too
Old 01-15-2020, 07:59 AM
^^^^^ do it
1981 930 euro
SOLD 1980 911 targa euro
Old 01-15-2020, 08:24 AM
Senior Member
Jdub's Avatar
Take a look at this page: Daniel Stern Lighting Consultancy and Supply
I believe there are several relay kits on the market. Not difficult to install and you will become familiar with your fuse panel, which you should inspect closely at the time of installation for loose screws, suspect fuses, etc. In fact, when I did the relay project I pulled off the negative lead from the battery and cross-referenced the existing fuses, installing fresh fuses of correct amp right across while also making sure the contacts where both clean and tight.
BTW, your dash panel lights are also unfused, another trouble point when smoke starts pouring out of the heat lever area. More about that via a search on this forum.
'78 Targa in Minerva Blue
Old 01-15-2020, 09:33 AM
Analog Air Cooled
Hotshot's Avatar
Thank you guys. Will get it done. Fusing Blower Fans atm. 86....
86 Targa
91 964
13 6 SPD Cayenne
Old 01-15-2020, 02:23 PM
sugarwood's Avatar
Are you saying the lack of relay burnt out his high beam stalk contacts? So, he needs a new turn signal stalk?
OP, I've forgotten details, but my high beams were not working (Not sure if it was flash or permanent), but i replaced my turn signal stalk and got back my high beams.
Pics of high beam turn signal replacement (and steering wheel and headlight switch)
1986 Bosch Icon Wipers coupe.
Old 01-15-2020, 02:30 PM
Analog Air Cooled
Hotshot's Avatar
High beams work. Low beams work, when you pull back to flash...no worky..
86 Targa
91 964
13 6 SPD Cayenne
Old 01-15-2020, 04:14 PM
Thread Killer
Teutonics's Avatar
This is also a good thread for reference: https://forums.pelicanparts.com/porsche-911-technical-forum/248149-turn-signal-switch-quick-fix-pictures.html
Allen
'85 911 Coupe
'75 BMW 2002
'02 Ducati Monster 900ie
'18 GMC Sierra Denali 6.2L 4wd
Old 01-16-2020, 06:01 AM
The more you pull back the handle to flash, the sooner you might have the self switching high beam problem. The action bends the flat bar that does the hi/low switching. So do it gently if you have to.
206 637 4071
Old 01-16-2020, 08:21 AM
Analog Air Cooled
Hotshot's Avatar
Good to know. Knew to the car and only realized now it wasn’t working..
86 Targa
91 964
13 6 SPD Cayenne
Old 01-17-2020, 04:11 AM
sugarwood's Avatar
So what are you going to do? Are you going to replace the turn signal stalk?
Old 01-17-2020, 07:56 AM
Mine was like that for YEARS, never knew why, I actually assumed that it was disabled or something in US cars.
Turns out that one time when I have the light switch out, I connected a certain wire to the wrong terminal. That wire feeds the high-beams when the lights are off and the stalk is pulled towards you.
Doh!
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 01-17-2020, 09:09 AM
FOr what it's worth, this was one of the first things I did on my car. I pulled the switch, cleaned the contacts, re-tensioned the strips (fairly obvious once you have it out what needs to go where), and reinstalled. 100k miles later it's still fine.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 01-17-2020, 10:24 AM
Analog Air Cooled
Hotshot's Avatar
Well like everything so far, I’ll fix before replacing. I have a Momo wheel the PO put on, looks simple enough to pop off and inspect. I’ll add it to the winter list.
It’s amazing how detailed you get when you can’t drive your car do to winter.
I’ve almost memorized the electrical system by now.
Headlight relays and fusing stuff Togo.
86 Targa
91 964
13 6 SPD Cayenne
Old 01-17-2020, 07:15 PM
