86 911's Avatar
Send a message via AIM to 86 911
New Door Stop - Too tight?
Hi All,
I know it's another door stop / door stay question but I searched with no luck. I bought the genuine Porsche door stop kit for my '76 911 driver's door this week. I triple checked and orientation is correct. Everything bolted on & installed smoothly. After putting in the pin, the door will not budge!
I try pushing on the door (putting maybe 50lbs of pressure of my own body weight) but it only bends the sheet metal where the door stay pin is mounted into. Are these just unusually tight? Or did I receive a defective part? Just thought I'd ask before I throw $40 on another one.
Matt
'76 Porsche 911 with '78 3.0 SC engine
'71 VW Bus
'14 VW Passat (toddler hauler & wife approved ride)
'03 Subaru Baja original yellow & silver
Old 12-14-2021, 02:47 PM
proporsche's Avatar
picture would help...if you are using the new type of the door stop ,they are very tight.I have always looked for old stock door stops..very much softer
ivan
here on ebay.com 2 good used ...403052032445 in your neighborhood....
1985 911 with original 502 191 miles...808 198 km
Old 12-14-2021, 04:23 PM
The new door stays are annoyingly stiff. But not like you describe. Something is wrong or jambed.
I took my new stays apart and modified them to not be soo stiff.
Old 12-14-2021, 05:47 PM
Porsche Addict
Are you positive you installed them correctly?
Lawrence - 1986 911 Carrera Coupe Grand Prix White
1959 Land Rover Series II
1962 Volkswagen Sedan Ragtop
1959 Porsche 356A Coupe
1971 Porsche 911T coupe
Old 12-14-2021, 06:13 PM
86 911's Avatar
Thanks guys. I tried it again and this time didn't chicken out. I pushed it a little faster and it finally gave.
They are annoyingly stiff. I never experienced such stiffness on any other vehicle. I really hope they loosen up a little more over time.
On another note, the bracket for the pin was overly stretched out, causing the annoying click. Shout out to JWW as the M6 bolt + nylon locking nut did the trick.
Matt
'71 VW Bus
Old 12-14-2021, 06:54 PM
Dr J's Avatar
Yes, they are too tight. This is how to fix it. Don’t take off too much though.
Door stop replacement.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 12-14-2021, 07:35 PM
Yep, that's how I loosened mine.
I don't believe they will get easier with use, unfortunately.
Old 12-14-2021, 08:14 PM
Yes, I just put one in and they are stiff.
Sold: 1989 3.2 coupe, 112k miles
Old 12-15-2021, 08:21 AM
Worth your time, before you rip the guts out of your door sheet metal. Minimizes pin clicking also.
Old 12-15-2021, 08:45 PM
