Power antenna 74 Targa
I ordered a Hirschmann power antenna from Tweeks, and it will not fit in the left fenderwell. Does anyone know of a attenna that will work for my 74 Targa?
John Arvanis
Old 04-04-2003, 08:08 AM
McDaniel's Avatar
Antenna
Another '74 Targa owner...
I know of no power antenna that will fit...I stayed with the manual
one, it pushes down all the way, (to avoid vandalism) and you
have a little "t" shaped key that inserts in the top to pull it up.
Where is your city in Illinois?
Impotence...Nature's way of saying "No hard feelings."
McDaniel
1974 911 Targa
1995 Toyota Avalon
2004 Toyota Tundra Extended Cab
Old 04-04-2003, 08:18 AM
Quad cities, East Moline
John Arvanis
Old 04-04-2003, 08:26 AM
McDaniel's Avatar
Ok
Thought maybe you were closer to the KY border...
nice to meet new people.
McDaniel
1974 911 Targa
1995 Toyota Avalon
Old 04-04-2003, 08:29 AM
Heck, I’m only 5 not 71!
targa80's Avatar
I have an 80 SC and it to has the manual antenna on the left side. THere is no room for the power antenna on the left. The factory manual provides the info to cut a hole on the right fender to install a power antenna. When I start to put the fenders back on my car I am considering doing the mod just for the convience of the power antenna.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 04-04-2003, 08:30 AM
I have a power antenna that looks like OEM it is stamped made in germany, and it is the smallest power antenna that I have ever seen.
There is no other markings so no clue at where it came from.
John Arvanis
Old 04-04-2003, 09:38 AM
How much was the Hirschman anteena from Tweeks? Thanks!
1997 993TT
1973 Carrera RS #1334
1970 911S sunroof coupe
'99 MBZ E55
1999, 2001 & 2003 daughters!
Old 04-04-2003, 09:45 AM
Targa Dude's Avatar
Send a message via AIM to Targa Dude
Hi John (arvanis), what year is your car? power antena's started in 78 and are mounted on the right side..
Jorge (Targa Dude)
Old 04-04-2003, 10:34 AM
ruf-porsche's Avatar
I think the power antennas that Tweeks currently sells are not the original Hirschman power antennas that were used in some P-cars.
Tweeks sells a lower cost alternative to OEM power antenna. If you want an original Hirschman antenna go to the Becker stereo website they still have a few recondition one.
Old 04-04-2003, 10:38 AM
My car is a 74 targa and the antenna is on the left front fender.
Tweeka cost is $80. and it is the alternate to OEM that does not fit.
Thanks for the Becker tip I will try them also
John Arvanis
Old 04-04-2003, 11:47 AM
This is Becker Website
http://www.beckerautosound.com
I believe all the manual antennas were install on the left side of the car while all car with power atennas were install on the right side of the car.
Had a 74 911 Coupe with manual antenna on the left side
Current 82 911 SC Targa has a power antenna on the right side.
One reason that Porsche may had move the antenna to the right side is that the drier for the a/c unit is located on the left side and most Porsche 911 shipped to the U.S. came with a/c, unless it was order with the a/c delete option.
I don't think even a OEM power antenna will fit the left side. At one time someone made a power antenna were the motor could be mounted remotely (2') from the mast. It was designed for location with limited access. Check the J.C. Whitney Catalog they may still have it.
Old 04-04-2003, 12:03 PM
