SEVENT9
Unclear on how to check for distributer pulse
First I apologize - this is another newbie question from me but I have checked all through the threads here and I cannot find this very specific detail for checking the distributer pulse and I am hoping someone can guide me through this. (I have posted this question on a thread relating to this but have yet to receive a reply so trying here).
When checking for distributor pulse following the instructions I have found on threads here do I probe 31D to 7 with my multimeter (VAC) (ie. 1 probe from multimeter on 7 and the other on 31d) or do I attach my multimeter negative to ground and then positive probe 31D and 7 separately?
When attaching probes to 31D and 7 I get no pulse which makes sense right, because no power is being delivered to the distributor? Is that correct?
But, when I then ground the multimeter and probe 31D I get pulse. I then did the same to 7 and have pulse.
Am I doing this correctly? Thanks everyone!! Appreciate any advice you can give.
Thanks as always!
Dan
SEVENT9
'79 SC Black: My first 911 & my birth year!!
http://forums.pelicanparts.com/porsche-911-technical-forum/1000359-79-outlaw-build-thread.html
Old 01-20-2020, 06:32 PM
First why are you checking for a pulse? Is the engine not starting? From your signature I assume you have a 79SC; I have a 78SC and when it didn't have a spark it turned out to be the green wire. I checked the pulse from the distributor by removing and spinning it by hand with a meter across contacts where the green wire plugs in and got a small pulse so replaced the green wire and fixed the problem.
1959 Bristol 406 (bought in 1972; sold in 1977)
1966 Porsche 2.0 coupe (bought in 1977; sold 1981)
1978 Porsche SC coupe (bought in 1993)
Old 01-21-2020, 12:56 AM
SEVENT9
Your correct I have no spark. I have tracked it to a possible faulty coil but while I wait for a new one to arrive I am checking everything else. I’ve followed a lot of threads on how to check the green wire which is what I am doing above. I’m just unsure if I am doing it correctly and hoping someone can clarify how to perform the test above properly. I don’t want to remove the dizzy and then have to reset the timing.
Old 01-21-2020, 03:23 AM
If your car is the same as mine there is a connector from the green wire that goes into the wiring harness (and eventually to the ignition box) somewhere near the left hand chain case. If you disconnect at that point you can check for a pulse between the two wires while cranking the engine. It's where you would disconnect the green wire if you were replacing it. If it's the original green wire then it could well be your problem.
Old 01-21-2020, 03:39 AM
SEVENT9
Yes that’s what I am doing but I am not sure if I am doing it correctly. If you wouldn’t mind re-reading my original post I have detailed how I am doing it but not sure which of the 2 methods I have tried is correct.
Old 01-21-2020, 03:40 AM
From your original post I assume you have disconnected the plug at the CDI module where there are 6 connectors. This is not the connector I am talking about. The green wire is quite short and there is a two-pin a connector (on my car at least) partly hidden by the distributor. See photo:
Old 01-21-2020, 05:16 AM
El Duderino
tirwin's Avatar
I’m thinking out loud here.
Just thinking through this logically. The reluctor in the distributor creates a magnetic field. Whenever the magnetic field is changed (rotor passes the TDC notch for example), this creates a voltage. The voltage is used to tell the CDI box when to fire.
My thinking is you would connect a test light to the two terminals on the dizzy. Remove the fuel pump relay and then try to crank the car. If the test light pulses, then you have a signal. You may have to flip the ends to get the right polarity. If that is successful, then you should disconnect the 6-pin on the CDI and check there. This would tell you if the signal is making it to the CDI box. If not, then it’s the green wire or somewhere else in the harness.
The reason I think you’d want to use a test light is the pulse would be happening so fast it would be hard to see on a meter.
The other way would be to pull the dizzy and spin the reluctor by hand.
Never tested it this way so I’m just spitballing in hopes that someone will either confirm or correct my thinking or will have an easier/better method.
Hope this helps!
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 01-21-2020, 05:20 AM
Something else I wrote a while back on how I think the ignition system works:
My understanding of spark generation on this car is as follows: the distributor generates a small voltage pulse which you can check by following above. The CDI transforms this to 400 volts which is then relayed to the coil which ups it to 20,000 volts. There could be a problem anywhere on this route. For example there is a connector to the green wire behind the distributor so you can also check there for the pulse if you don't get it at the CDI end of the cable. In my case it was the green wire: Bentley suggests distributor is faulty in absence of pulse but in my case it was the green wire, confirmed by pulling the distributor and bench testing: distributor gave a pulse when rotated by hand.
Old 01-21-2020, 05:23 AM
SEVENT9
Thanks guys, I agree with everything you say. I am just trying to verify to correct way to administer the following test for the green cable & distributor because I am new and unsure if I am doing it correctly. This is what I am doing (from original post)
”When checking for distributor pulse following the instructions I have found on threads here do I probe 31D to 7 with my multimeter (VAC) (ie. 1 probe from multimeter on 7 and the other on 31d) or do I attach my multimeter negative to ground and then positive probe 31D and 7 separately? When attaching probes to 31D and 7 I get no pulse which makes sense right, because no power is being delivered to the distributor? Is that correct?“
My reason for doing all this is that I have a non-start and am working through a step-by-step diagnosis. I suspect it’s the coil and have a new one coming and while I await it’s delivery I am testing everything else. The test above for continuity for the green cable which is discussed in many threads here is just a little unclear for a newbie like me and I am trying to work out if I am doing it correctly.
I really don’t want to have to pull the distributor to figure this out and the test above will be the next step to guide me as to whether I need to go that far or not. It would be frustrating to pull the dizzy to test this if I don’t have to.
Old 01-21-2020, 05:37 AM
SEVENT9
That’s exactly right but I am testing at the CDI end of the same cable which is easier to access due to the rotation of my distributor. When I test this am I doing it correctly by attaching my DMM negative to ground and producing DMM positive to each terminal (7 & 31d) while cranking?
Old 01-21-2020, 06:08 AM
You are looking for a pulse between 7 and 31d. So you are not doing it right according to Bentley, who says that absence of a pulse means distributor is most likely at fault, completely overlooking that it may be a break in a wire. I don't know why you are getting a pulse between 31d and ground or between 7 and ground UNLESS they are now common. When the green wire failed on my car I had continuity between the two wires in the green cable.So try testing for continuity between 7 and 31d (no need to crank). I am assuming your DMM has a continuity tester.
Old 01-21-2020, 06:43 AM
El Duderino
tirwin's Avatar
Right. The reluctor in the dizzy generates voltage from the magnetic field. It’s a sine wave - it increases and decreases. One wire is the signal and the other is the shield (ground). This is why you sometimes have to swap these wires if you replace the original Bosch CDI with an aftermarket (like MSD).
I’m not sure if the original Bosch actually uses this voltage to fire the coil. I suspect it just uses it a signal to know when to fire. Power likely comes from the 12v power feed.
If there is no signal at the CDI plug, then the next step would be to test at the dizzy.
Old 01-21-2020, 06:58 AM
SEVENT9
JSV - I followed your instructions here (thank you!!) and **** got weird, check this out!!
So in the pic below you can see at first the sticker of the side of my CDI indicating that 31d & 7 pins are at the bottom, teeth of connector facing left. So I tested continuity here and got nothing indicating a green wire fault right? So I unwrap all the wiring inside the engine bay and discovered this....
...my Green Wire runs from the dizzy all the way up (no connector en route) to the top part of pins at the CDI connector. I check continuity here and have it! So my "Green Wire" seems to be ok (resistance across pins measures 575 Ohms).
I can't figure out why my system would work if wired backwards to the "original" sticker on the side of the Bosch CDI unit so I check Bentley which shows the pins per my setup, 31d & 7 at top of connector when connector teeth face left. Stranger still is the fact that any replica stickers also show this opposite configuration.
I am not sure what any of this means but it seems that every replacement sticker produced is incorrect or my system and Bentleys manual are backwards.
Regardless off all this it seems that I do have continuity through my Green Wire so it should;t need replacing. I am hoping I ave done this all correctly because reading up on a green wire replacement and it looks like a total PIA - Pelican's wire is much shorter with a connector on the end of it so there seems to be no way to splice it into the socket at the CDI - strange.
SEVENT9
Old 01-21-2020, 08:25 AM
El Duderino
tirwin's Avatar
What CDI do you have? It sounds like someone swapped the green and violet wires for an aftermarket unit that triggers on the opposite slope from the original Bosch.
Old 01-21-2020, 08:39 AM
SEVENT9
I wish it were that simple - nope, I have the original Bosch CDI. I was just told on my instagram post that this sticker is for the CDI connections rather than the plug itself and is therefore a mirror of the plug. It's a poor way to illustrate this in my opinion as it should either be mounted the other way up. (Either that or this is my excuse for being an idiot!)
SEVENT9
Old 01-21-2020, 08:58 AM
I'm not familiar with your cable set up; maybe it is an aftermarket replacement? I'm not sure what continuity you are checking. There should be infinite ohms between 7 and 31d when no cranking is taking place; at least that is my understanding. The green wire on my car failed when I had continuity between the two wires; there is still continuity end to end. The problem is when the shielding makes contact with the inner wire, so you could well have continuity on your green wire end to end, but you definitely don't want continuity between 31d and 7.
The fabled green wire is actually a cable with a center wire with metal shielding on the outside encased in green insulation. I am assuming that there is also insulation around the inner wire to prevent shorting with the shielding. I think that it is this inner insulation (not visible) that breaks down. The green wire you are looking at is not the green cable as at that point it has been separated into two wires. What does the cable at your distributor end look like?
Old 01-21-2020, 09:15 AM
SEVENT9
I followed the Green Wire I show above from the distributer up the wiring harness to the CDI and it's 100% the same cable which splits and goes into the correct pins on the CD connector. At the distributer end it looks like this, I just now unsure how to check it properly:
SEVENT9
Old 01-21-2020, 10:07 AM
Still not clear if there is continuity between 7 and 31d. If there is a short between the two then that is perhaps why you get the pulse to ground on both of them; they are both transmitting the pulse from the distributor. Put your probes between 31d and 7 and measure the resistance or have you done this and it was 575 ohms? If it is possible, wriggle the green cable while you do this. Should be a very high value of ohms or it's a short. Do not crank during this test.
Old 01-21-2020, 11:23 AM
SEVENT9
Thanks for helping with this mate! Below is a pic of the continuity test. This is just for the purposes of a photo (had to hold the camera with one hand) usually my hands would be much further up the probes but reading is the same: 575 - and a wiggle of the Green Wire made absolutely no difference at all, not a single Ohm, stayed steady at 575.
SEVENT9
Old 01-21-2020, 11:28 AM
Your meter looks to be showing 575 K Ohms, so that's quite a high value (575,000 ohms). So cable would appear to be good. How exactly do you check for pulse between 7 and ground? What do you see on your meter?
Old 01-21-2020, 12:01 PM
