-   -   Rubber boot in shift tunnel over transmission snout (http://forums.pelicanparts.com/porsche-911-technical-forum/1050556-rubber-boot-shift-tunnel-over-transmission-snout.html)
archstanton 05-02-2020 08:21 PM
Originally Posted by stevie 77 930 (Post 10831044)
Yes, you can work the boot from inside the car, but the shift coupler needs to be removed first. Use some dish soap or silicone lube on the boot and you should be fine.
Thanks!
