-   -   Reverse Light Out 92 C2 Help Please (http://forums.pelicanparts.com/porsche-911-technical-forum/105107-reverse-light-out-92-c2-help-please.html)
gripit 04-04-2003 07:53 AM
I HAVE A 92 C2 AND THE REVERSE LIGHTS ARE OUT. FUSES AND BULBS CHECK OK. CAN'T FIGURE IT OUT. I SEARCHED THE ARCHIVES BUT FOUND NOTHING TO HELP EXCEPT SWITH ON TRANSMISSION? ANY OTHER SUGGESTIONS? THANKS
69 911s 04-05-2003 12:47 AM
How far have you traced the problem?
jester911 04-05-2003 12:59 AM
I think yours is same as mine. (earlier carrera) The switch for the reverse lights is on the tip of the tranny. This switch seems to be intermittent on my car. I haven't got around to fixing it yet but if fuse and bulbs are ok then that is what has to be fixed or replaced.
69 911s 04-05-2003 01:39 AM
on the g50/50 the switch is on the passenger side of the trans and if the boot is not firmly in place or cracked, then it gets crud in it pretty easily. been there, done it.
Jim Smolka 04-05-2003 02:19 AM
Check the wiring behind the boot. Could be broken and just need to be soldered.
Speedster94 04-05-2003 12:24 PM
hallo
If your Car is a Tiptronic the Switch is in the Console and your Shifter pushes it .
harald
plain fan 11-01-2004 02:57 PM
So is the reverse switch position in the same place as a 915? Thanks in advance.
