Porsche Crest Reverse Light Out 92 C2 Help Please
I HAVE A 92 C2 AND THE REVERSE LIGHTS ARE OUT. FUSES AND BULBS CHECK OK. CAN'T FIGURE IT OUT. I SEARCHED THE ARCHIVES BUT FOUND NOTHING TO HELP EXCEPT SWITH ON TRANSMISSION? ANY OTHER SUGGESTIONS? THANKS
Old 04-04-2003, 08:53 AM
Send a message via AIM to 69 911s
How far have you traced the problem?
when you see hoof prints, dont automatically assume zebras
Old 04-05-2003, 01:47 AM
Driving member
jester911's Avatar
I think yours is same as mine. (earlier carrera) The switch for the reverse lights is on the tip of the tranny. This switch seems to be intermittent on my car. I haven't got around to fixing it yet but if fuse and bulbs are ok then that is what has to be fixed or replaced.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 04-05-2003, 01:59 AM
on the g50/50 the switch is on the passenger side of the trans and if the boot is not firmly in place or cracked, then it gets crud in it pretty easily. been there, done it.
Old 04-05-2003, 02:39 AM
Jim Smolka's Avatar
Check the wiring behind the boot. Could be broken and just need to be soldered.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 04-05-2003, 03:19 AM
hallo
If your Car is a Tiptronic the Switch is in the Console and your Shifter pushes it .
harald
Old 04-05-2003, 01:24 PM
So is the reverse switch position in the same place as a 915? Thanks in advance.
Grady aka plain fan
66 912 - enjoying the good life
78 911 SC and 90 C2 turbo look cab - gone but not forgotten
01 996 TT -
09 Audi A4 Avant - daily driver
Old 11-01-2004, 03:57 PM
