Battery power supply to ignition switch
Im doing my 911 68.
I have the wiring diagram in front of me. I cannot see where the ignition switch is fed from the battery. I take it has constant 12v and when the ignition is turned on a wire from it feeds to the engine. I have tracked the starter wire but not the 12 volt feed from the ignition switch to the engine bay.
Car is a non runner and has been attacked by the previous owner. So I'm wanting to get it half right before I go cranking it.
Thanks Lyndon
Old 01-29-2020, 04:07 PM
Under the radar
Trackrash's Avatar
Assuming it is the same as a 69 it gets the power from the fuse block. Part of the fuse block is hot from the battery.
Gordon
'71 911 Coupe 3,0L outlawed
Old 01-29-2020, 05:30 PM
Battery to fuse 3. Heater. So this goes nowhere.
Battery to starter. Then to the block in the engine bay. Then it goes to a relay fed by the starter wire on the ign switch.
Alternator B+ is also from the battery.
Fuel pump is fed by fuse 1.
It looks like fuse 1 is fed via the ignition switch but I can't see what feeds the ign switch.
I guess I will find out when I put a battery in it.
Lyndon
Old 01-29-2020, 05:41 PM
Under the radar
Trackrash's Avatar
There are connections on the back of the fuse block. On the '69 fuses 1-5 are actually connected by a strip on the back of the fuse block. Could be the case with yours. Hope that helps.
Gordon
Old 01-29-2020, 07:22 PM
I will have a look.
Thanks Lyndon
Old 01-29-2020, 07:23 PM
ROW '78 911 Targa
timmy2's Avatar
Battery positive black wire to fuse 3 that is internally jumpered to 2 & 4. Fuse 2 red to light switch terminal 30 then goes to ignition switch terminal 30. Then switched power goes out terminal 15 back to fuse 1.
Schematic:
https://www.dropbox.com/s/laojh5hm43qqtyl/65%20to%2068.jpeg?dl=0
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 01-29-2020, 08:01 PM
Makes it easy when you know what your looking for. Found it. I find electrical stuff a challenge.
Thanks Lyndon
Old 01-29-2020, 08:08 PM
And that feeds fuse 1 when the ign is on which feeds my fuel pump and no doubt my coil.
Old 01-29-2020, 08:10 PM
Im fitting msd. So no need for the resitor via the coil. Should be able to clean up the engine bay nicely.
Old 01-29-2020, 08:13 PM
ROW '78 911 Targa
timmy2's Avatar
Thanks Lyndon
Dennis
Old 01-29-2020, 09:30 PM
If you remove fuse number 1, the ignition switch and related circuits are dead. Thus, no. 1 is the voltage source for the ignition.
This is handy to know when the car stops working in the middle of a ride.
Sherwood
Old 01-30-2020, 02:05 AM
A good place for a kill switch.
Lyndon
Old 01-30-2020, 05:02 AM
