Url Url is offline
Url's Avatar
Distributor allen head screw rounded, how to remove?
I am disassembling my distributor to clean / lube / check / rebuild if needed but noticed that one of the allen head screws was rounded by the PO.
Access is very tight so difficult to use a bolt extractor, drill it out, ...
Anyone had this before and can guide me in how to get it out?
Old 01-21-2020, 01:10 AM
Url Url is offline
Url's Avatar
Old 01-21-2020, 01:13 AM
If possible you could tap a tight torx bit in with a hammer. The tapping can contribute to loosening the screew
Old 01-21-2020, 01:15 AM
Url Url is offline
Url's Avatar
I have tried that but didn't work out ...
Next on the list is use JBWeld to fix a bit in there and hope it'll come out ... Fingers crossed
Any other idea's?
Old 01-22-2020, 08:14 AM
Attempt all the usual non-destructive fastener removal techniques first. This forum is chock full of posts related to stuck threaded fasteners.
If those fail, chuck in a drill press or milling machine and remove the screw head that holds that plate in place. The screw can then be removed and the threads cleaned up or replaced with a thread insert.
Sherwood
Old 01-22-2020, 08:33 AM
Here's also a great bolt removal tool:
Old 01-22-2020, 09:57 AM
Url Url is offline
Url's Avatar
Got it out last week
Bought new easy outs, German brand and not the typical Amazon / eBay stuff Chinese stuff. Drilled the bolt, easy out in and came right out!
Once again, having the right tools pays off ...
Old 01-31-2020, 12:00 PM
