| Cars and Cappuccino | Quote:
				__________________ http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) | ||
|  02-06-2020, 08:12 AM |
| Registered Join Date: Feb 2014 Location: Lomita, CA
				 | Quote:
 Bosch should have used a 100 ohm resistor instead of 10 ohms, that would have prevented damage to the I.C.
				__________________ Dave | ||
|  02-06-2020, 04:09 PM |
| Registered |
			yes - remove one side of the resistor and that'll be perfect protection against this unfortunate failure mode. And in the unlikely event you ever need/want to restore the DME to stock you can just solder the resistor leg down again.
				__________________ 1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 | ||
|  02-06-2020, 05:18 PM |
 Either of you gents have a picture of said resistor, for those of us who have never peeked inside an ECU?
|  02-07-2020, 05:13 AM |
			Here's the resistor (R786), which was changed from 10 ohms to 100 ohms.
|  02-07-2020, 08:07 AM |
| Registered |
			Reviving this thread to clarify one thing.  How come this resistor R786 is labelled 0R on the schematic? Until I read the posts above I always thought this was merely a 0-ohm resistor, or some sort of jumper to go over PCB traces. Is the schematic wrong and is this resistor indeed a 10-ohm resistor?
				__________________ Gilles RoW 88 Carrera coupé | ||
|  07-02-2025, 01:17 AM |
				 | Quote:
				__________________ Dave Last edited by mysocal911; 07-02-2025 at 04:45 AM.. | ||
|  07-02-2025, 04:28 AM |
| Registered |
			Dave, thank you, I had noted this recommended change to 100 ohms. So you confirm the schematic is wrong about this resistor value and it should read 10R, not 0R? Asking this because I'm currently editing my own copy of the Motronic schematics with annotations for ease of understanding, so I might take the opportunity to also fix any error. I have already fixed the swap between signals ADV12 and ADV13 and changed the R10 value to 0R10 for the current sense resistor (R786).
|  07-02-2025, 06:57 AM |
				 | Quote:
 The original value was 10 ohms, which causes a failure of the 0127 when wiring problems occur.
				__________________ Dave Last edited by mysocal911; 07-02-2025 at 08:49 AM.. | ||
|  07-02-2025, 08:40 AM |
| Registered |
			Sorry, my bad. I meant R409, which is indeed the current sense resistor that goes to pins 14 and 15 (injector drive line). This resistor value is shown as R10, while it is in fact 0.1 ohms. So it should be labelled 0R10.  As for resistor R786 that goes to pin 11 (tach upshift indicator), its value is currently labeled 0R and I will relabel its value to 10R. As I said I have also swapped signals ADV12 and ADV13 and changed their arrow head directions accordingly. If you know of other errors on these schematics, please let me know. Thanks.
|  07-02-2025, 09:50 AM |
| Registered |
			Just curious, was the upshift light only on US models ? I ask as I am not aware of that function on any UK cars. Ant.
				__________________ "But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla | ||
|  07-03-2025, 06:36 AM |
| Registered |
			Same for us in France, never seen a shift light.  So, as I understand it, this indicator lights up when the injector pulse width reaches a certain value AND the engine speed is above a certain RPM threshold. The logic for both these conditions is inside the tach.
|  07-03-2025, 07:59 AM |
Correct, it's a special IC (~ 24 pins) in the tach doing the calculations.
|  07-03-2025, 08:04 AM |
| Registered |
			One more customized IC that is no longer available?
|  07-03-2025, 09:10 AM |
| Registered |
			Cheers Gilles.   Ant.
|  07-03-2025, 09:13 AM |
| Registered |
			Interesting! Any idea why it was limited to certain markets ? Ant.
|  07-03-2025, 09:15 AM |
| Registered |
Cheers Ant,  Currently trying to decipher and understand as much as I can from the Motronic schematics. My circuit analysis ability has gone long ago and those schematics are not easy to follow. Trying to annotate them for reference. Does anybody know why the ADC appears not powered? VCC is connected to ground via a 4.7k resistor. Or is it powered via VREF+ and VREF-? I may open a dedicated thread later to ask other questions, hoping that guys like Dave, Ingo, Sal and others will chime in.
|  07-03-2025, 09:28 AM |
| Registered |
			I believe the up-shift light was added to the US market cars in an attempt to improve fuel efficiency. The idea being if you shift to a higher gear sooner you will burn less fuel.
|  07-03-2025, 09:31 AM |
				 | Quote:
 Vcc (+5V) is pin 11. Various semiconductor suppliers produced this part.
				__________________ Dave Last edited by mysocal911; 07-03-2025 at 11:29 AM.. | ||
|  07-03-2025, 09:58 AM |
| Registered |
			Side question: For us folks that are high level Object Oriented Is there any kind of Entity Relationship Drawing (ERD) that shows the flow of the logic thru the fundamental logic blocks for a typical Motronic ECU???
				__________________ 1980 911 - Metzger 3.6L 2016 Cayman S | ||
|  07-03-2025, 11:11 AM |
