-   -   intermittant poor running solved (http://forums.pelicanparts.com/porsche-911-technical-forum/1051504-intermittant-poor-running-solved.html)
gwmac 02-02-2020 12:28 PM
http://forums.pelicanparts.com/uploa...1580675170.jpg
I've been chasing this for a while, 45 year old Bosch saves the day!
911obgyn 02-02-2020 12:47 PM
What year car?
Stock coil replaced flamethrower?
gwmac 02-02-2020 02:04 PM
74, yes
shadowjack1 02-03-2020 04:54 AM
Happy it worked out.
pmax 02-03-2020 12:18 PM
Good for you.
Just need the symptoms to complete the picture. Power loss, rough idle, no start ?
bkreigsr 02-04-2020 08:20 AM
<iframe width="567" height="425" src="https://www.youtube.com/embed/nXKeNKvl-J4" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
...the flamethrower was the culprit or the solution ?
... the flamethrower was 45 years old, lost, then found, or your original was 45 years old, and defective?
gwmac 02-04-2020 08:28 AM
Car would stumble and die at an intersection and then restart and run fine, loss of power at higher revs sometimes. Finally got to where if I applied full throttle engine would just quit until i eased back . I was convinced it was the CIS but I was wrong. Had the timing light on it when it happened to act up, give it some throttle and the light would go out but the tach stayed steady.
Installed an old Bosch Blue and shes running good.
