gwmac's Avatar
intermittant poor running solved
I've been chasing this for a while, 45 year old Bosch saves the day!
Old 02-02-2020, 12:28 PM
What year car?
Stock coil replaced flamethrower?
Old 02-02-2020, 12:47 PM
gwmac's Avatar
74, yes
Old 02-02-2020, 02:04 PM
1988 Carrera
shadowjack1's Avatar
Happy it worked out.
88' Carrera
79' SC gone (lost to Katrina)
75' Targa gone
72'914 gone
72' 914 gone too
Old 02-03-2020, 04:54 AM
Still here
pmax's Avatar
Good for you.
Just need the symptoms to complete the picture. Power loss, rough idle, no start ?
Old 02-03-2020, 12:18 PM
cycling has-been
bkreigsr's Avatar
...the flamethrower was the culprit or the solution ?
... the flamethrower was 45 years old, lost, then found, or your original was 45 years old, and defective?
Old 02-04-2020, 08:20 AM
gwmac's Avatar
Car would stumble and die at an intersection and then restart and run fine, loss of power at higher revs sometimes. Finally got to where if I applied full throttle engine would just quit until i eased back . I was convinced it was the CIS but I was wrong. Had the timing light on it when it happened to act up, give it some throttle and the light would go out but the tach stayed steady.
Installed an old Bosch Blue and shes running good.
Old 02-04-2020, 08:28 AM
