two electrical brake switches
Mine is an 86 Carrera
question : why did Porsche used two electrical brake switches on master cylinder?
I disconnected one plug or other and the brake light still work...
Old 12-13-2019, 05:09 PM
2 cicuits
probably because there are 2 braking circuits in the car
Old 12-13-2019, 05:13 PM
are you sure ? is it has something to do with the front and rear of the master cylinder?
Old 12-13-2019, 05:26 PM
SCadaddle's Avatar
Redundancy.
Old 12-13-2019, 05:36 PM
Originally Posted by SCadaddle View Post
Redundancy.
that could be right
Old 12-13-2019, 05:46 PM
Under the radar
Trackrash's Avatar
Actually, it is part of the brake warning light circuit. If one of the brake circuits is down on fluid, the imbalance will turn on the brake warning light on the dash, since there is a switch on each circuit.
Gordon
'71 911 Coupe 3,0L outlawed
Old 12-13-2019, 06:32 PM
Bill Verburg's Avatar
Bill Verburg
Old 12-14-2019, 07:04 AM
Originally Posted by Bill Verburg View Post
Nice
Hey Bill
I only have two pole connector no middle pole on both switches stock
Old 12-14-2019, 01:21 PM
Under the radar
Trackrash's Avatar
Some of the older cars had two connector switches.
Gordon
Old 12-14-2019, 01:47 PM
Hey Tracktrash
I did some testing
I disconnect one of the switches and I apply the brake pedal down and I only see just the right side of the brake light on and reconnect and disconnect other one and the left brake on not right side..
sound like each of the electric switch only work one side of the rear brake light .
Old 12-14-2019, 05:32 PM
The switch I posted above was used through '83, from '84 they went to the 2 pole design, which just has 81 & 82a, these are simple on/off switches for the brake lights.
Bill Verburg
Old 12-14-2019, 07:00 PM
Under the radar
Trackrash's Avatar
Bill, I miss-spoke. On my '71 the switch actually only has one connector. But electrically, as shown on the schematic it has two poles, which is why I called it a two connector. '74 is the same.
So either way it looks like the OP has the incorrect switches? Or is his description of how his brake switches operate one brake light each correct?
Frank, do you have an extra unused wire connector hanging by the switches?
Gordon
Old 12-14-2019, 07:10 PM
No I don't extra unused wire connector
It must have two connector plug in ,each operate one side of the rear brake light
it is strange
I could bridge the wires together into one switches only .
Old 12-14-2019, 07:50 PM
Diss Member
Quicksilver's Avatar
The pressure based switches are a bit failure prone. The way they fail is it takes more and more pressure to get them to turn on until they just don't work. Having the two switches in parallel is a good way to have redundancy to avoid a light failure plus as pointed out before: The brake system has redundant front and rear brake circuits so if one fails the brake lights should still come on.
The described situation where one switch does one rear light and the other switch controls the other side is either an error in testing or someone did a major hack job on the wiring harness.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 12-15-2019, 05:28 PM
brake light, etc...
I have a 78 SC. Recently noticed the following.
1. Front Pass. parking light inoperative
2. Rear Pass running lights (back and side) inop.
3. Rear Pass brake light inop.
4. Pass side reverse light inop.
5. Turn signals work fine.
Checked fuses/bulbs. Using a multimeter, determined that there is power to the rear pass running light (back) when the lights are on. I'm alone and haven't tested brake light or reverse light circuit.
Had a mechanic look at it and he expressed opinion that something wrong with housing since when a bulb is inserted no illumination.
Any suggestions for rather testing or cure?
Old 02-05-2020, 06:07 PM
Check the ground on the pass rear housing.
Could be a bulb or corrosion in the socket on the pass front.
Old 02-05-2020, 08:24 PM
