-   -   EGR Delete on '79 SC (Help Needed!) (http://forums.pelicanparts.com/porsche-911-technical-forum/1052344-egr-delete-79-sc-help-needed.html)
thefaculty 02-11-2020 08:24 AM
Hi everyone,
I will be installing SSIs soon and as I have the CIS out I want to do a full EGR delete as the SSIs will not accommodate the downpipes from the EGR. I'd like to remove the unit in full and cannot find a thread to do so using search here.
Can I simply remove the EGR, cap the 2 vacuum lines and also somehow cap the larger line that meets at the base of the air box?
If so does anyone know what I could use to cap it at the base?
http://forums.pelicanparts.com/uploa...1581438113.jpg
timmy2 02-11-2020 10:20 AM
Cap the vacuum lines with rubber caps made to do so.
Then take the pipe fitting to Canadian tire or others and match up the threads for a plug on the airbox.
Or find someone local with a blow airbox that will give you the plug that comes standard on non-EGR Cars.
Solamar 02-11-2020 11:25 AM
Belmetric is a good source for both the vac plugs and EGR plug (sorry, I dont know the size).
https://www.belmetric.com/metric-drain-plugs-c-11_90/
https://www.belmetric.com/metric-inch-vacuum-plugs-c-13_745/
pmax 02-11-2020 11:41 AM
There's no sensor or CEL to trigger so this should require nothing more than removing the tubes and plugging the holes.
boyt911sc 02-11-2020 12:02 PM
AAR aluminum vacuum tube.......
theFaculty,
It looks like the aluminum vacuum tube for the AAR & AAV shown in your picture has some serious abrasion. This will be your chance to patch that section with some JBWeld before putting the CIS unit back.
http://forums.pelicanparts.com/uploa...1581451136.jpg
Tony
Flojo 02-13-2020 02:18 AM
get a plastic plug of some sort from the hardware store and JB weld it inside.
no NASA fix.
thefaculty 02-13-2020 05:09 AM
Originally Posted by boyt911sc (Post 10749204)
theFaculty,
Tony
Thanks for spotting Tony, I wouldn’t have known about this and will definitely patch it!!
thefaculty 02-13-2020 05:11 AM
For the plug on the air box I have just found that an oil drain plug is the perfect fit with a crush washer!!
timmy2 02-13-2020 09:00 AM
Good to know. :)
2jmotorsports 02-13-2020 09:30 AM
Hot rodding at its finest.
Aztim 02-13-2020 10:04 AM
On page 3 I have the info you'll need for the plugs
http://forums.pelicanparts.com/porsche-911-technical-forum/1001414-my-first-porsche-3.html
Paulporsche 02-13-2020 02:00 PM
Dan,
Tony is right about those tubes. I had a hole developing in mine that was about 1/4" in dia that had the material worn down to about the thickness of aluminum foil. It may have partly to blame for a start/run issue Tony helped me solve. I took a curved piece from a mop handle and JB welded it into place over the hole.
thefaculty 02-16-2020 01:13 PM
Quick update on this - I discovered that the drain bolt for the oil sump plate is a perfect fit plug the hole in the airbox left by removal of the EGR! :)
(yes I know it's not fully in - just showing it fits. I used a crush washer and tightened by hand +1/8 turn.)
http://forums.pelicanparts.com/uploa...1581887534.jpg
