SEVENT9
EGR Delete on '79 SC (Help Needed!)
Hi everyone,
I will be installing SSIs soon and as I have the CIS out I want to do a full EGR delete as the SSIs will not accommodate the downpipes from the EGR. I'd like to remove the unit in full and cannot find a thread to do so using search here.
Can I simply remove the EGR, cap the 2 vacuum lines and also somehow cap the larger line that meets at the base of the air box?
If so does anyone know what I could use to cap it at the base?
SEVENT9
'79 SC Black: My first 911 & my birth year!!
http://forums.pelicanparts.com/porsche-911-technical-forum/1000359-79-outlaw-build-thread.html
Old 02-11-2020, 08:24 AM
ROW '78 911 Targa
timmy2's Avatar
Cap the vacuum lines with rubber caps made to do so.
Then take the pipe fitting to Canadian tire or others and match up the threads for a plug on the airbox.
Or find someone local with a blow airbox that will give you the plug that comes standard on non-EGR Cars.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 02-11-2020, 10:20 AM
Belmetric is a good source for both the vac plugs and EGR plug (sorry, I dont know the size).
https://www.belmetric.com/metric-drain-plugs-c-11_90/
https://www.belmetric.com/metric-inch-vacuum-plugs-c-13_745/
1978 SC Targa
Old 02-11-2020, 11:25 AM
Still here
pmax's Avatar
There's no sensor or CEL to trigger so this should require nothing more than removing the tubes and plugging the holes.
Old 02-11-2020, 11:41 AM
AAR aluminum vacuum tube.......
theFaculty,
It looks like the aluminum vacuum tube for the AAR & AAV shown in your picture has some serious abrasion. This will be your chance to patch that section with some JBWeld before putting the CIS unit back.
Tony
Old 02-11-2020, 12:02 PM
Flojo's Avatar
get a plastic plug of some sort from the hardware store and JB weld it inside.
no NASA fix.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 02-13-2020, 02:18 AM
SEVENT9
Originally Posted by boyt911sc View Post
theFaculty,
Tony
Thanks for spotting Tony, I wouldn’t have known about this and will definitely patch it!!
Old 02-13-2020, 05:09 AM
SEVENT9
For the plug on the air box I have just found that an oil drain plug is the perfect fit with a crush washer!!
Old 02-13-2020, 05:11 AM
ROW '78 911 Targa
timmy2's Avatar
Good to know.
Dennis
Old 02-13-2020, 09:00 AM
Perpetual Reassembler
2jmotorsports's Avatar
Hot rodding at its finest.
Jose - 1983 911SC Coupe
Instagram: @joe_engineer
911 D I Y Blog: joe-engineer d o t c o m
D I Y Vids: https://www.youtube.com/joeengineer
Old 02-13-2020, 09:30 AM
On page 3 I have the info you'll need for the plugs
My first porsche
Old 02-13-2020, 10:04 AM
Designer King
Paulporsche's Avatar
Dan,
Tony is right about those tubes. I had a hole developing in mine that was about 1/4" in dia that had the material worn down to about the thickness of aluminum foil. It may have partly to blame for a start/run issue Tony helped me solve. I took a curved piece from a mop handle and JB welded it into place over the hole.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 02-13-2020, 02:00 PM
SEVENT9
Quick update on this - I discovered that the drain bolt for the oil sump plate is a perfect fit plug the hole in the airbox left by removal of the EGR!
(yes I know it's not fully in - just showing it fits. I used a crush washer and tightened by hand +1/8 turn.)
SEVENT9
Old 02-16-2020, 01:13 PM
