How bad is the factory jack?
Bilstein Green Dot Jack -
I don't have a jack, car didnt come with one. It's on my short list of things I need to buy (as opposed to the "long list"). I've read mention that it is soo bad that your better off bringing something else (944 alum scissor jack?). Is it really THAT bad? I will only use it for the very rare flat tire, I'm fully versed in using dangerous jacks (Hi-Lift Jack anyone?). Securely prevent the car from rolling, solid base for jack and NEVER climb under car supported by jack. I really like that it has a built in storage bracket for it in the trunk...
1978 SC Targa |
abides.
No, it's fine. I've used mine many times.
I think some people carry the 944 jack because it is lighter.
Graham 1984 Carrera Targa |
gearhead
It’s only bad if you have rocker or sill rust.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Driver
Used it for the first time last year. Worked just fine.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Great, glad to hear it!
1978 SC Targa |
I used the one on my 914 zillions of times. The one on my 911 has never been used, but I know it will work.
The biggest thing is make SURE the car is in gear, the the parking brake is fully applied. Chock the wheels if there is any forward or backward movement of the car. You want to be 100% sure the car can't move forward or backward while in the air. And for sure don't get under the car if that is the only thing holding it up. If you are on dirt or soft ground you will have a difficult time. And find a level place. For any real maintenance get a regular floor jack, and a jack pad.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
AutoBahned
It’s only bad if you lack a good orthopedic surgeon.
Get the scissors type 944 jack and carry a piece of plywood in the car. |
Since I'm familiar with how to use the jack (make sure it's positioned so that it's vertical when you start lifting the car with it and make sure the car's secure so it doesn't shift while lifting the car with it), I trust the jack for its intended purpose. What am I missing? |
Dont worry, I'm a professional
1978 SC Targa |
AutoBahned
The base of the jack is far too small to be safe in any perturbation from absolute vertical.
It's been called the "widow-maker" - some concours guys carry one to shows to get points (along with the scissors type to use). |
i used to use the 944 scissor jack all the time when working on my 944. It was just pretty unremarkable - did the job.
I thought I needed a factory jack for the 911 years ago. I bought a green-dot one (not correct for my car - apparently better than the one that would be), and jacked the car up to swap the wheels, on a level concrete floor. I stopped before I could get a jack stand under the car, lowered it and used the trolley jack and lollipop adapters instead. Haven't touched the green-dot since. I suppose I'd use the factory jack to put on the spare if it was all I had. But a small 3500 lb trolley jack is more stable, raises the car faster for less effort, cost $50 or so and wedges perfectly well in the front of the trunk/doesn't move around at all. Cheaper and works better. I also find my FLAPS 4-way wheel brace has a lot more leverage than the factory one in the toolkit. I thought I needed a Porsche-branded air compressor. Turned out generic ones work better (faster/quieter) & are cheaper too... i mean, if you've almost got a concours-worthy time capsule with the disposable gloves, original fanbelt, matching factory luggage and all that noise, then sure, go for it. But if you want tools to do a job (or more than one) - better value to be had than replacing the missing factory items, IMO.
'77 S with '78 930 power and a few other things. |
Under the radar
Those jacks are scary. Only for emergencies with the wheels blocked. Even then I had my car fall using one of those.
Banned
I used mine a bunch until the gear threads jammed, but otherwise it's fine so long as you, make sure the car is secure, move slowly and make sure to do all of your wrenching on the wheel lugs only before and after raising the car.
That reminds me that I need to buy another. Edit: Christ, why are they so expensive?! |
AutoBahned
they are expensive because they are de rigueur for concoursmobiles
why do you want one? the scissors type is smaller, safer & weighs less use a floor jack at home |
abides.
If your car is very low, like mine, it works great to get the car off the ground a bit so you can slide a floor jack under.
72 911 Although it is done at the moment, it will never be finished. |
this jack is rock solid and does it's job probably longer than we live.
this jack is just there to lift and make a tire change! not to hold the car up when restoring it! ok. so I'm not the only one, haha :-)
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
AutoBahned
tire changes must often be done on surfaces that are not completely flat or slanted
even if a "perfect flat surface" any small bump can cause the car to come down in any direction please don't encourage unsafe work practices |
