Dr944S2's Avatar
Video: Installing a SSI exhaust system on a Porsche 911 SC
Hi.
the video gives you a detailed step by step tutorial how to replace the exhaust system of your Porsche 911 G by a SSI exhaust system. For doing this the oil cooling system of you engine has to be modified, because the larger heat ecchangers are in conflict with an oil pipe. The video shows also this in detail.
http://www.youtube.com/watch?v=x6Qs63QO-ug
The video has a German soundtrack, but English subtitles are available on YouTube. If you don't see them by defualt, watch the video directly on YouTube and enable the subtitles with the button below the frame.
Enjoy it,
Jürgen
Old 02-17-2020, 02:26 AM
Dr J's Avatar
Saw it. Great video. I also saw his turbo tie rod video which in passing shows how to get the steering rack out. Very good. The rear shock one is also good. It was down to the level of adding talcum powder to the rubber as a dry lubricant.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 02-17-2020, 03:22 PM
911 Mania
Good video, He had none of the required hammer adjustments (indentations) to fit I’ve read about. Anybody know why he didn’t?
"When the debate is lost, slander becomes the tool of the losers." Socrates
Old 02-17-2020, 04:46 PM
Looking at the heat exchanger when he was installing it already looked to be dented in.
Old 02-17-2020, 06:46 PM
Dr944S2's Avatar
Hi,
right, I had to "adjust" the heat exchangers with the hammer in several places. I thought this was only with my model the case.
Greetings,
Jürgen
Old 02-18-2020, 02:06 AM
good find! saving this one for later.
Current Cars: 87 Carrera RS/IROC Tribute, 92 12V Jetta GLI, 07 Ford Explorer, 91 Miata track car
Previous Cars: 00 Carrera, 01 996tt, 07 997tt, APR tuned 12 Beetle
Instagram: @pdklol
Old 02-18-2020, 04:26 AM
1978 911 SC
Big thank you to Jürgen for making this video. I Just finished this project. Made my life so much easier having this video. Thanks again !!
1978 911 SC Complete rebuild, 83 engine, SSi’s M&K Sports muffler.
Old 05-07-2022, 05:45 AM
Tags
exchnger , exhaust , heat , ssi
